Setup on Fedora
supersam
Setup on Fedora
Post by supersam » Fri Jan 27, 2023 9:08 am
Hi there,
I'm using makemkv for a while now and am really happy.
But now I switched to fedora and don't get the direct blue ray playback to work.
As makemkv, VLC and Kodi all come as a flatpack, they work perfectly but don't seem able to communicate with each other.
The usual tipp
sudo ln -s libmmbd.so.0 /usr/lib/
doesn't work and Aribb24 doesn't seem to be available as a package.
Has anyone had any luck with direct playback on fedora and can share some insights into how to set it up?
Thank you very much!
Falco
Re: Setup on Fedora
Post by Falco » Sat Jan 28, 2023 5:57 pm
Hi SuperSam
Why you don't try to use with RPM packages for Kodi and VLC.
You can also compile and install MakeMKV (instead of Flatpack).
Maybe you will have a better result to do them communicate.
Regards
supersam
Re: Setup on Fedora
Post by supersam » Sun Jan 29, 2023 6:50 pm
Thank you for the answer!
It did work great that way.
Install VLC and kodi via dnf/rpm
and compile MakeMKV (I followed this guide https://linuxconfig.org/how-to-install- ... dora-linux)
You can delete this post if redundant :)
Regards
Falco
Re: Setup on Fedora
Post by Falco » Mon Jan 30, 2023 6:36 pm
Great if I succeded to help you 8) :D
Enjoy then
