Hi. I have just got a bp55 slimline external usb drive. I have used the sdf tool flasher thing it is now on bp60 ffirmware and it now will load uhd blurays (which it didnt out of the box on 1.03 fw)
but i cant get it to open/decrypt the disk. i tried 2 different disks and this is what i get.
Product: BD-RE BP60NB10
Revision: 1.00
Serial number: SIK03M1xxxxx
Firmware date: 2117-11-21 17:20
Firmware version: 1.00
Disc Information
Label: JURASSIC_WORLD_DOMINION
Timestamp: 2022-06-21 17:33:09
Protection: AACS2.0/C v76
Data capacity: 87.50 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.17.2 win(x64-release) started
Error 'OS error - Access is denied' occurred while creating 'F://MKB20_v61_save.tgz'
Using LibreDrive mode (v06.3 id=4ACF8047C3AC)
Error 'OS error - Access is denied' occurred while creating 'F://MKB20_v61_BLUE_PLANET_II_D1_2F73.tgz'
Error 'OS error - Access is denied' occurred while creating 'F://MKB20_v76_save.tgz'
Error 'OS error - Access is denied' occurred while creating 'F://MKB20_v76_Jurassic_World_Dominion_AFD5.tgz'
im new to flashing and not sure if i did something wrong these are the things i used.
LG/Hitachi BP 55 Please help
Daveo
Re: LG/Hitachi BP 55 Please help
Your issue is you can't write to F you changed it to a place you don't have permission to write or that does not exist or even more silly your trying to write to the drive itselfDaveo wrote: Sat Jan 28, 2023 12:56 pm Hi. I have just got a bp55 slimline external usb drive. I have used the sdf tool flasher thing it is now on bp60 ffirmware and it now will load uhd blurays (which it didnt out of the box on 1.03 fw)
Revision: 1.00
Disc Information
Number of layers: 3
Daveo
Thanks though another member beat you to it. that was the problem FYI this drive now works like a charm. way better than my old asus.
