Hoosiers - No disc inserted
rolette
#1 Post by rolette » Thu Jan 26, 2023 12:18 am
I picked up The Jock Collection, which includes Hoosiers, Rocky and DodgeBall. When I try to load Hoosiers with MakeMKV v1.17.2, it takes a few minutes then reports "no disc inserted".
I cleaned the disc, reconnected the drive, restarted MakeMKV and rebooted the computer. None of that helped, so I exchanged the set and got the same problem with the new set. The other two discs read fine, but Hoosiers won't even load.
Turned on debug logging and here's all I get:
Debug log started at Wed Jan 25 23:44:21 2023 , written by MakeMKV v1.17.2 win(x64-release)
001005:0000 MakeMKV v1.17.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\rolette/MakeMKV_log.txt
DEBUG: Code 3 at `6CF;l<+`$x9]D6No(y!wmrg:29395310
SDF  v097: HL-DT-ST_BD-RE_BU40N_1.00_211612201528_MOFM2QE2607
Any idea what "code 3" is? Anyone else been able to successfully rip Hoosiers from The Jock Collection?
Here's the drive info in case that is relevant:
OS device name: E:
Product: BD-RE BU40N
Revision: 1.00
Serial number: MOFM2QE2607
Firmware date: 2116-12-20 15:28
Highest AACS version: 77
Firmware version: 1.00
Re: Hoosiers - No disc inserted
#2 Post by dcoke22 » Fri Jan 27, 2023 7:21 pm
Do you have a different drive you can try? It is my experience that some optical drives just don't like some discs.
