Halloween Ends (2022)
I'm trying to rip this title but my drive just spins and spins. My computer won't even read the disc to get a dump file. I've tried four different computers, mac and PC (but still only have the one external drive). Has anyone had success with this title?
GasmaskAvenger
Re: Halloween Ends (2022)
Just tested it out and MakeMKV just opened it up for me.
NOTE: My copy of the disc is a US pressing from the Best Buy steelbook, in case you're wondering.
MasterDB2205
@bcrush
Got the same problem.
the German versions can be successfully saved with makemkv
MasterDB2205
Well, I can't confirm that. The discs simply stops at about 50% and nothing happens.
Having issues with this disc as well, mine is from the 4K Halloween Trilogy set.
Edit: after restarting my computer twice, it seems like it was able to get the movie and features fine. Weird
MasterDB2205
Version 1.17.3 is out and the German edition of the UHD still cannot be read. Too bad.
I can only say that my German rental versions could be copied to the hard drive without errors
the copy also runs correctly on the Dune Player
Issue with this UHD title in Australia as well.
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Saved AACS dump file as MKB20_v77_Halloween_Ends_D631.tgz
MasterDB2205
It still doesn't work. It doesn't work for the red fox either.
MasterDB2205
Volume key unknown or stopping in the middle like you say earlier?MasterDB2205 wrote: Tue Jun 13, 2023 7:35 pm![]()
Version 1.17.4 is out and the German edition of the UHD still cannot be read.
Stopping in the middle usually points to a bad or dirty disc or drive
MasterDB2205
The disc stops at about 40%. But the disc is absolutely clean and the drive only has these problems with this disc.MasterDB2205 wrote: ↑Tue Jun 13, 2023 9:35 pm
Clean it anyway with a damp lint free microfiber cloth and dry with another.MasterDB2205 wrote: Wed Jun 14, 2023 12:25 pmThe disc stops at about 40%. But the disc is absolutely clean and the drive only has these problems with this disc.MasterDB2205 wrote: ↑Tue Jun 13, 2023 9:35 pm
After that exchange the disc if it still don't work
