Choosing the Correct Video/Audio Track
ophedian
Post by ophedian » Thu Jan 26, 2023 1:14 am
I am running MakeMKV on my MacBook Pro M1 Max. I have a few discs which show having a LOT of the same Title and I am thinking the disc is NOT even large enough to store that many Titles. However, this makes it difficult to choose the correct feature.
For example for my "Close Encounters Of the Third Kind" Anniversary Edition... MakeMKV is showing so many Titles I am not sure which one to choose.
Normally I would choose the largest one, is this normal??
Is something going on with MakeMKV or Drive? :(
Please see attached image for what I am seeing...
Title Selection Screen in MakeMKV
Screenshot 2023-01-25 at 8.07.25 PM.png (166.79 KiB) Viewed 7068 times
wmcclain
Re: Choosing the Correct Video/Audio Track
Post by wmcclain » Thu Jan 26, 2023 2:47 am
This is a very common situation and often discussed here. See viewtopic.php?f=1&t=16791
Do you have java jre installed? That will often sort out the proper playlists.
ArArdin
Post by ArArdin » Thu Jan 26, 2023 9:23 am
Note there are three different versions on this anniversary disc. And it's not uncommon for MakeMKV to show every title two times; often the title's playlist is listed as well as the concerning m2ts file(s). Dropping down the listed items will show you more info.
ophedian wrote: Thu Jan 26, 2023 1:14 amI have a few discs which show having a LOT of the same Title and I am thinking the disc is NOT even large enough to store that many Titles.
There's a way of disc authoring called "seamless branching". Where every version is chopped up in smaller m2ts files. In such a way that most of these parts are the same. Obviously these need only one time to reside on disc. Each version has its own playlist, which carries info of which m2ts files must be played consecutively. Your choice of version at the disc menu dictates what playlist will be loaded.
