cinavia
maxone
cinavia
Post by maxone »
any plans on getting a fix for cinavia?
thanks.
crowfax
Re: cinavia
Post by crowfax »
MakeMKV simply removes copy protection and then copies the audio/video/subtitle streams to an MKV container. Removing cinavia would require altering of the data stream.
maxone
Re: cinavia
Post by maxone »
i understand that, but isn't this program supose to remove all copy protection. isn't cinavia a copy protection. just wondering.
thanks.
skittle
Re: cinavia
Post by skittle »
No one has a solution for cinavia yet. Removing it is not a lossless process and is not trivial.
The best workaround is to simply purchase a device that does not support cinavia. *hint: only a few actually support it in the first place*
setarip_old
Re: cinavia
Post by setarip_old »
@maxone
Hi!
As I stated in my most recent post to the Cinavia "sticky" here:
If substantiated, the following might signal the "beginning of the end" for Verance/"Cinavia" protection, at least regarding the many PS3s used for Blu-ray playback:
http://forum.doom9.org/showpost.php?p=1 ... tcount=894
