Automatically Select All Angles
GenosseKupferbart
Post by GenosseKupferbart »
Hey there,
I currently run a makeMKV docker on unRaid, while using the in-built auto-ripper for convenience.
I recently noticed that different angles of a video are not automatically selected. I even went as far as changing the selection rule to '+sel:all', yet they are still not selected. The same happens on a Windows machine.
I don't mind if makeMKV would create extra files per angle, I'd rather have them ripped automatically and later decide on which to keep.
Any help would be much appreciated
Re: Automatically Select All Angles
I don't have much experience with the 'auto-ripper' nor do I know how to do the selection you're looking for.
How do you handle discs with playlist obfuscation? These discs often have 100 or more playlists of the main movie. 100+ * ~25GB is a lot of space and a lot of time ripping from the disc.
What is the correct play list [insert title here]?
A recent example: Multiple Titles
