Edworld
Post by Edworld »
I ran the script 4,3 and got this message:
tsMuxeR version git-a10bea3. github.com/justdan96/tsMuxer
Unknnown exception. It does not have to be! Please contact application support team for more information.
"The script has completed"
quietvoid wrote:
Tue Jan 24, 2023 12:42 am
johnjon94 wrote:
Sun Jan 22, 2023 11:42 pm
I would love to test a 64 bit build! I'm not sure if its because the Shield isn't compatible with this version, but when I install the Plex addon I just get an endless loading bar with the Plex logo
I've made new builds available here: https://github.com/quietvoid/xbmc/releases/tag/v21-dovi
There are both 32 bits and 64 bits APKs.
The only change from the last build is that the new build also fixes grey letterbox bars when playing cropped Dolby Vision videos for FireTV.
Info thread: https://forum.kodi.tv/showthread.php?tid=371557
Where are the previous builds?
quietvoid
Post by quietvoid »
MartyMcNuts wrote:
Wed Jan 25, 2023 5:02 am
Which builds? The one from 2021-01-23? It was replaced.
I'm not keeping multiple builds up on there.
quietvoid wrote:
Wed Jan 25, 2023 2:44 pm
The version before the current one as from the previous few posts it seems the new version doesn't work very well.
quietvoid
Post by quietvoid »
MartyMcNuts wrote:
Wed Jan 25, 2023 8:26 pm
There's no difference except that it doesn't crash.
I don't have the previous version anymore.
afarvvik
Post by afarvvik »
RESET_9999 wrote:
Tue Jan 24, 2023 8:30 pm
afarvvik wrote:
Tue Jan 24, 2023 10:29 am
thanks for the reply @RESET_9999.
i'll check out the mp4 workflow.
TS/M2ts container is not letting me FF/RW at all. Jellyfin just freezes, the webos player says "function not available right now". is there a particular tsmuxer version that needs to be used?
then it's a jellyfin bug because you can FF/RW on the plex app with TS/m2ts files.
can you please confirm if you can FF/RW on the WebOS media player app with TS/m2ts files?
yossSP
Post by yossSP »
Hi all, I'll launch a question to @RESET_9999 and every other member of this forum.
There's a guy in other forum of my country where I'm in who claims that the FireTV Stick 4K (2018 version) can now playback Dolby Vision FEL titles.
As far as I know there's no FireTV that could playback FEL files using the EL layer. From what I have guessed and taking into account that the guy is basing his claim on viewings with naked eye, this device is playing FEL titles as MEL (without using EL layer), what already has a great quality as is.
Could anybody confirm or deny this statement?
afarvvik wrote:
Wed Jan 25, 2023 8:50 pm
I just tested my C8 with DV TS files and I can confirm that FF/RW works on both PLEX and webOS app.
the file i tried had closed gop though
yossSP wrote:
Wed Jan 25, 2023 10:39 pm
He's probably talking about quietvoid's new kodi build that can play P7 as P8. Read just a couple comments above.
quietvoid
Post by quietvoid »
My 2018 4K stick hasn't been updated in years but it never could play FEL, blank screen.
The 2021 4K Max behaves the same, with latest firmware.
johnjon94
Post by johnjon94 »
Thanks! You said that you don't use Plex for Kodi - what do you generally use to playback Dolby Vision files on Kodi?
Facakente
Post by Facakente »
Hi there , I have installed one of nightly master last builds on my firestick 4k and now I get DV when playing a mkv file .
Though when checking color standard output in dev mode in the firestick 4k , i get bt2020_10_hdr10 , when in Disney or Netflix app I get bt2020_10_dovi , which was what I would expect to see also in kodi when playing mkv.
Codec states Dolby vision and my tv gets the flag for DV , however color output in the firestick dev mode looks wrong .
Any thoughts ?
quietvoid
Post by quietvoid »
johnjon94 wrote:
Thu Jan 26, 2023 6:23 pm
I use PlexKodiConnect or a NFS server.
plex_p8_dovi
Post by plex_p8_dovi »
quietvoid wrote:
Tue Jan 24, 2023 5:05 pm
ragico wrote:
Tue Jan 24, 2023 4:46 pm
I have installed your latest build on my firestick 4k max and the .ts files p5, p8 and p7 do not work anymore.
When I try to open any of them Kodi closes. Still works with mkv.
Before this update everything worked perfectly.
Thanks, I also get the crash for .ts.
I'll look into it later.
I found the issue, it seems I can't convert the RPU from .ts for now.
The arm-v7a release was updated, I'll do the other later.
It should fix the crash but .ts profile 7 won't be converted.
Your kodi build makes me think about a plex plugin that would convert, on the fly, dvhe.07.06 BL+EL+RPU mkv remuxes to p8 ts.
Would it be technically possible ?
If it is the case, it would be a great solution for lg [c8 -> c2] oled tvs.
for lg c8 / c9, dual layer p7 mp4 remuxes are the best solution, in particular for FEL titles.
I'm ok to make those when there is effectively EL content but for RPU only titles, on the fly plex conversion would be very handy.
set PLEX=download/install plex server and get the transcoder from the installation folder (you can uninstall it once you got the files)
in the TOOLS_READ_ME.txt (Dolby-Vision-Scripts @RESET_9999)
doesn't imply the plex plugin I suggest, right ?
ragico
Post by ragico »
quietvoid wrote:
Tue Jan 24, 2023 11:39 pm
ragico wrote:
Tue Jan 24, 2023 9:36 pm
Yes working again but not P7 as you said.
Curious because before, everything was working perfectly, including P7 as I said a few posts before.
I doubt it was actually converting, maybe you were just playing MEL files.
Sorry no. All my P7.ts are from Dovi Fel on purpose. None is from a Mel. And I can assure you that they worked and played perfectly. Unfortunately I did not keep that version.
