ragico
#7906
Post
by ragico » Tue Jan 24, 2023 4:46 pm
quietvoid wrote: ↑Tue Jan 24, 2023 12:42 am
johnjon94 wrote: ↑Sun Jan 22, 2023 11:42 pm
I would love to test a 64 bit build! I'm not sure if its because the Shield isn't compatible with this version, but when I install the Plex addon I just get an endless loading bar with the Plex logo
I've made new builds available here:
https://github.com/quietvoid/xbmc/releases/tag/v21-dovi
There are both 32 bits and 64 bits APKs.
The only change from the last build is that the new build also fixes grey letterbox bars when playing cropped Dolby Vision videos for FireTV.
Info thread:
https://forum.kodi.tv/showthread.php?tid=371557
I have installed your latest build on my firestick 4k max and the .ts files p5, p8 and p7 do not work anymore.
When I try to open any of them Kodi closes. Still works with mkv.
Before this update everything worked perfectly.
quietvoid
#7907
Post
by quietvoid » Tue Jan 24, 2023 5:05 pm
ragico wrote: ↑Tue Jan 24, 2023 4:46 pm
Thanks, I also get the crash for .ts.
I'll look into it later.
I found the issue, it seems I can't convert the RPU from .ts for now.
The arm-v7a release was updated, I'll do the other later.
It should fix the crash but .ts profile 7 won't be converted.
MastaG
#7908
Post
by MastaG » Tue Jan 24, 2023 6:15 pm
Just a quick question.
Without using RESET_9999's scripts..
Lets say I have created my final hevc file.
And I want to pack it into a m2ts file with audio.
Can I just use tsmuxerGui to add the movie.hevc as the first track.
And then open the main playlist from the original bluray disc and add the TrueHD+ac3 core audio as second track.
Then just mux both tracks into a m2ts container.
The reason I'm asking is because my movie 1917 triggers DV on all devices but doesn't play audio.
Even when selecting the core ac3 one its all silent.
I notice many people are using eac3to but what for?
The audio is on the original bluray disc, why should I mess with it?
#7909
Post
by RESET_9999 » Tue Jan 24, 2023 8:30 pm
afarvvik wrote: ↑Tue Jan 24, 2023 10:29 am
thanks for the reply @RESET_9999.
i'll check out the mp4 workflow.
TS/M2ts container is not letting me FF/RW at all. Jellyfin just freezes, the webos player says "function not available right now". is there a particular tsmuxer version that needs to be used?
then it's a jellyfin bug because you can FF/RW on the plex app with TS/m2ts files.
MastaG wrote: ↑Tue Jan 24, 2023 6:15 pm
yes thats how you do it.
ragico
#7910
Post
by ragico » Tue Jan 24, 2023 9:36 pm
quietvoid wrote: ↑Tue Jan 24, 2023 5:05 pm
Yes working again but not P7 as you said.
Curious because before, everything was working perfectly, including P7 as I said a few posts before.
MastaG
#7911
Post
by MastaG » Tue Jan 24, 2023 10:28 pm
RESET_9999 wrote: ↑Tue Jan 24, 2023 8:30 pm
Thats the strange thing, I just tested it with 1917 on my LG C8 in m2ts format.
Both Plex and Emby let me select between TrueHD and ac3 5.1.
I know the LG C8 doesn't support TrueHD, but when I select ac3 5.1 all audio seems silent in both players.
Could it be that some movies carry an empty ac3 track?
quietvoid
#7912
Post
by quietvoid » Tue Jan 24, 2023 11:39 pm
ragico wrote: ↑Tue Jan 24, 2023 9:36 pm
I doubt it was actually converting, maybe you were just playing MEL files.
#7913
Post
by RESET_9999 » Tue Jan 24, 2023 11:43 pm
MastaG wrote: ↑Tue Jan 24, 2023 10:28 pm
I could be wrong but IIRC my C8 cannot even play the ac3 core of TrueHD for a DV TS/M2ts.
you should convert TrueHD/DTS to EAC3. 6-3-4 in my script.
caelar900
#7914
Post
by caelar900 » Wed Jan 25, 2023 2:13 am
RESET_9999 wrote: ↑Tue Jan 24, 2023 12:03 pm
since most movies have l2 trim passes, not much difference. The problem seem to be with L1 high max_pq values that have no effect.
Okay cool. Good to know.
I am still curious what your personal preference is between internal and x800. If you don't mind sharing!
Edworld
#7915
Post
by Edworld » Wed Jan 25, 2023 3:36 am
I ran the script 4,3 and got this message:
tsMuxeR version git-a10bea3. github.com/justdan96/tsMuxer
Unknnown exception. It does not have to be! Please contact application support team for more information.
"The script has completed"
#7916
Post
by MartyMcNuts » Wed Jan 25, 2023 5:02 am
Info thread:
Where are the previous builds?
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
quietvoid
#7917
Post
by quietvoid » Wed Jan 25, 2023 2:44 pm
MartyMcNuts wrote: ↑Wed Jan 25, 2023 5:02 am
Which builds? The one from 2021-01-23? It was replaced.
I'm not keeping multiple builds up on there.
#7918
Post
by MartyMcNuts » Wed Jan 25, 2023 8:26 pm
quietvoid wrote: ↑Wed Jan 25, 2023 2:44 pm
The version before the current one as from the previous few posts it seems the new version doesn't work very well.
quietvoid
#7919
Post
by quietvoid » Wed Jan 25, 2023 8:41 pm
MartyMcNuts wrote: ↑Wed Jan 25, 2023 8:26 pm
There's no difference except that it doesn't crash.
I don't have the previous version anymore.
afarvvik
#7920
Post
by afarvvik » Wed Jan 25, 2023 8:50 pm
can you please confirm if you can FF/RW on the WebOS media player app with TS/m2ts files?
