The Green Mile 4k UHD
taldren
#1 Post by taldren » Tue Jan 24, 2023 6:33 pm
Tried 3 different drives (2 at 1.17.2 and 1 at 1.16.7):
Debug log started at Tue Jan 24 18:27:25 2023 , written by MakeMKV v1.16.7 win(x64-release)
001005:0000 MakeMKV v1.16.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\root/MakeMKV_log.txt
005075:0000 The new version 1.17.2 is available for download at http://www.makemkv.com/download/
DEBUG: Code 3 at wPw@X*c]4mg& [n>)i&~--ZG:29395310
SDF v097: HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIK07KBRF0645
001011:0000 Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
DEBUG: Code 2147483648 at vY-GuZ@?5^tcx_N8:121264625
003332:0000 Saved AACS dump file as file://C:\Users\root/.MakeMKV/MKB20_v76_Green_Mile_B4F3.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at EVz_tTp6BRfYN?zX:29396092
001003:0020 DEBUG: Code 0 at EVz_tTp6BRfYN?zX:29395172
Purchased from Amazon.
trevork99
Re: The Green Mile 4k UHD
#2 Post by trevork99 » Tue Jan 24, 2023 10:30 pm
I was also having issues with this disc. Here's my topic with the errors I got: viewtopic.php?f=12&t=30075
With what you got (and the authentication errors I'm getting when trying to make a backup), I'm willing to bet that a dump for this release wasn't submitted yet.
lfoust
#3 Post by lfoust » Thu Jan 26, 2023 6:56 pm
I was able to rip my copy from Amazon. Strange that you would be getting errors - I don't think it is common for there to be different discs of the same release from the same retailer. Here is how the discs mapped out for me: https://thediscdb.com/movie/the-green-m ... es/2022-4k
trevork99
#4 Post by trevork99 » Sun Jan 29, 2023 12:16 pm
Weird how you got your copy to work; I tried ripping the movie file again and I still got many "Invalid Field in CDB" errors, and attempting to make a backup actually resulted in MakeMKV creating folders and such, but the program skipped over all the disc files (with errors of course) and thus made no attempt to back them up. Of note, the last attempt I made at ripping the movie file actually threw five read errors.
I don't understand why it would be doing all of this, as I threw the disc in my LG UBK90 UHD player and it seemed to work with no problems. At this point I may just buy a replacement disc but I would still like to know if anyone has any solutions before I give up.
Trickyd-1
#5 Post by Trickyd-1 » Sun Jan 29, 2023 8:21 pm
The answer lies 6 lines from the bottom of your log.
“003303:0000 The volume key is unknown for this disc - video can't be decrypted”
Dump needs to be submitted or is still being processed by Mike.
Also, it’s very common and a design feature of AACS v2.x for there to be many different versions of 4k discs.
trevork99
#6 Post by trevork99 » Mon Jan 30, 2023 2:23 am
I had a feeling something like this is the reason why seemingly similar looking discs can sometimes run into problems while others work without issue.
I'm still wondering if not having a submitted dump also has anything to do with the "Invalid Field in CDB" errors, otherwise I may just try again in a week or two and see if the dump was processed.
krutoileshii
#7 Post by krutoileshii » Mon Jan 30, 2023 10:30 pm
submitted the dump.
krutoileshii
#8 Post by krutoileshii » Wed Feb 01, 2023 12:12 am
Should be good.
adamthefilmfan
#9 Post by adamthefilmfan » Thu Jun 15, 2023 7:46 pm
Same issue, different error log code.
Submitted a second error dump file today (first was on the 9th June 2023).
MakeMKV v1.17.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Adam/MakeMKV_log.txt
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Saved AACS dump file as C:\Users\Adam/.MakeMKV/MKB20_v76_Green_Mile_8BA5.tgz
DEBUG: Code 0 at 6o}7w.Puikol{)H3:213132721
DEBUG: Code 0 at 6o}7w.Puikol{)H3:213131341
