Correct macOS installation?
alexreg
Post by alexreg »
I initially installed MakeMKV through Homebrew on macO, which use the macOS installer on the download page of the website.
However, I initially got this error when trying to run `makemkvcon`.
Failed to execute external program 'mmgplsrv' from location '/opt/homebrew/bin/mmgplsrv'
To fix that, I symlinked some other binaries in `/Applications/MakeMKV.app/Contents/MacOS`; namely, `mmccextr`, `mmgplsrv` (the one being complained about), and `sdtool`. Is this the correct thing? It certainly makes the above error disappear, but I just wanted to check, as I submitted a pull request to Homebrew for performing these symlinks (into `/opt/homebrew/bin`).
Also, even with these symlinks in place, I still get the following error every time I run `makemkvcon`.
Profile parsing error: default profile missing, using builtin default
This doesn't seem to actually get in the way of using `makemkvcon`, but I was wondering if I should have a "default profile" somewhere. Should I?
alexreg
Re: Correct macOS installation?
Post by alexreg »
bump
What happens if you run the GUI?
I've always installed manually using the installer from the website. Normally I run the GUI, but sometimes use the command line. I've never had issues like you describe this way.
alexreg
Post by alexreg »
dcoke22 wrote:
Tue Jan 24, 2023 2:39 am
Indeed, I don't get the issue in the GUI, only the CLI.
