Predator Ultimate Edition BD+
stickleback
#1 Post by stickleback » Sat Sep 18, 2010 9:24 am
Having a problem with Region 2 version of Predator Ultimate Edition. Im using the latest allcombo.svq but getting failed to process disc.
Karl
setarip_old
Re: Predator Ultimate Edition BD+
#2 Post by setarip_old » Sat Sep 18, 2010 5:03 pm
Hi!
Download and try the just-released v.1.6 of MakeMKV...
stickleback
#3 Post by stickleback » Sat Sep 18, 2010 8:59 pm
Tried the latest version but still no joy.
Karl
setarip_old
#4 Post by setarip_old » Sat Sep 18, 2010 10:49 pm
Sounds like you have a dirty or damaged disc...
What AACS number did MakeMKV display?
stickleback
#5 Post by stickleback » Sun Sep 19, 2010 9:54 am
The disc is brand new. BD+ AACS v17, BD+. Its failing on the BD+ decryption (using latest allcombo.svq), details below:
MakeMKV v1.6.0 darwin(x86-release) started
Optical drive "BD-ROM TSSTcorp DVD-ROM SH-D162C TS04" opened in OS access mode.
Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH41N PQ05" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BH08LS20 2.00" opened in OS access mode.
Loaded 37 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00001.svq
Failed to process BD+ code using generic SVQ from builtin/00001.svq
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /Users/karl/Movies/SVQ/dump_PREDATOR_D7B67FE7B4FBEFA5.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
setarip_old
#6 Post by setarip_old » Mon Sep 20, 2010 2:16 am
Hi!
Did you submit the SVQ dump file?
#7 Post by mike admin » Mon Sep 20, 2010 8:32 am
Added to SVQ, should work now. BD+ status updated at http://www.makemkv.com/forum2/viewtopic.php?f=5&t=612
AchiveAndy
#8 Post by AchiveAndy » Mon Jan 23, 2023 7:14 am
Any update on this? I can open the disc, can back it up as well, but the video stutters when I try to seek manually forward or backward. I don't know what the problem is.
#9 Post by Woodstock » Mon Jan 23, 2023 2:46 pm
You are asking about a dozen-year-old post.
Most likely, your video playback device cannot handle the amount of data present.
