Halloween Ends (2022)
bcrush
#1 Post by bcrush » Fri Jan 06, 2023 12:49 pm
I'm trying to rip this title but my drive just spins and spins. My computer won't even read the disc to get a dump file. I've tried four different computers, mac and PC (but still only have the one external drive). Has anyone had success with this title?
GasmaskAvenger
Re: Halloween Ends (2022)
#2 Post by GasmaskAvenger » Thu Jan 12, 2023 6:30 am
Just tested it out and MakeMKV just opened it up for me.
NOTE: My copy of the disc is a US pressing from the Best Buy steelbook, in case you're wondering.
MasterDB2205
#3 Post by MasterDB2205 » Tue Jan 17, 2023 4:23 pm
@bcrush
Got the same problem.
arito3
#4 Post by arito3 » Sun Jan 22, 2023 7:43 am
the German versions can be successfully saved with makemkv
MasterDB2205
#5 Post by MasterDB2205 » Thu Jan 26, 2023 6:00 am
arito3 wrote: Sun Jan 22, 2023 7:43 am the German versions can be successfully saved with makemkv
Well, I can't confirm that. The discs simply stops at about 50% and nothing happens.
sk0gg1es
#6 Post by sk0gg1es » Thu Feb 02, 2023 10:51 pm
Having issues with this disc as well, mine is from the 4K Halloween Trilogy set.
Edit: after restarting my computer twice, it seems like it was able to get the movie and features fine. Weird
MasterDB2205
#7 Post by MasterDB2205 » Fri Feb 03, 2023 5:44 am
Version 1.17.3 is out and the German edition of the UHD still cannot be read. Too bad.
arito3
#8 Post by arito3 » Fri Feb 03, 2023 3:58 pm
I can only say that my German rental versions could be copied to the hard drive without errors
the copy also runs correctly on the Dune Player
ajob61
#9 Post by ajob61 » Sat Feb 04, 2023 3:29 am
Issue with this UHD title in Australia as well.
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Saved AACS dump file as MKB20_v77_Halloween_Ends_D631.tgz
MasterDB2205
#10 Post by MasterDB2205 » Mon Mar 06, 2023 11:12 am
Any Updates??
MasterDB2205
#11 Post by MasterDB2205 » Sun Apr 02, 2023 1:59 pm
It still doesn't work. It doesn't work for the red fox either.
MasterDB2205
#12 Post by MasterDB2205 » Tue Jun 13, 2023 7:35 pm
:( :( Version 1.17.4 is out and the German edition of the UHD still cannot be read. :( :(
#13 Post by Billycar11 » Tue Jun 13, 2023 8:49 pm
MasterDB2205 wrote: Tue Jun 13, 2023 7:35 pm :( :( Version 1.17.4 is out and the German edition of the UHD still cannot be read. :( :(
Volume key unknown or stopping in the middle like you say earlier?
Stopping in the middle usually points to a bad or dirty disc or drive
MasterDB2205
#14 Post by MasterDB2205 » Wed Jun 14, 2023 12:25 pm
MasterDB2205 wrote: ↑Tue Jun 13, 2023 9:35 pm
The disc stops at about 40%. But the disc is absolutely clean and the drive only has these problems with this disc.
#15 Post by Billycar11 » Wed Jun 14, 2023 5:25 pm
MasterDB2205 wrote: Wed Jun 14, 2023 12:25 pm
Clean it anyway with a damp lint free microfiber cloth and dry with another.
After that exchange the disc if it still don't work
