LG-BU40N
escence
LG-BU40N
#1 Post by escence » Fri Jan 20, 2023 4:43 pm
Heho,
just a short question in addition to the sticky uhd drive flash / recommendation post:
Is this one: https://www.amazon.de/LG-BU40N-ARAA10B- ... 108&sr=8-2
the mentioned LG BU40N ?
I am bit unsure because of the Hitachi-LG Part.
Thanks and sorry for my bad english.
Re: LG-BU40N
#2 Post by Coopervid » Fri Jan 20, 2023 5:38 pm
Heho,
It is. However, I suggest you buy this:
https://www.amazon.de/Verbatim-Externer ... 9hdGY&th=1
It comes with an enclosure and contains a Pioneer UHD drive. But please be aware that it only works with Makemkv and AnyDVD.
escence
Re: LG-BU40N
#3 Post by escence » Fri Jan 20, 2023 6:12 pm
I am actually just planing ripping my complete UHD collection.
So the verbatim is a good choice, yes?
Does it need a flash? Or is it like Pioneers "flash-free" ?
Re: LG-BU40N
#4 Post by dcoke22 » Fri Jan 20, 2023 9:02 pm
Only the Pioneer drives are 'flash-free'. The LG will need to be flashed. The BU40N is a good drive, though.
If you don't want to mess with it, the flashing guide sticky post has a list of sellers who will sell you a flashed and tested drive.
escence
Re: LG-BU40N
#5 Post by escence » Fri Jan 20, 2023 9:16 pm
My question was aimed towards the suggested verbatim one housing Pioneer technique.
Does this one needs to be flashed?
Re: LG-BU40N
#6 Post by Coopervid » Fri Jan 20, 2023 11:34 pm
No. If you want to stick with Makemkv and AnyDVD it is perfect and doesn't need to be flased.
escence
Re: LG-BU40N
#7 Post by escence » Sat Jan 21, 2023 6:06 am
I have one Last question:
What does stick with MakeMKV and AnyDVD means?
My Plan was ripping with Make to Movie only (no menues, Extras…) and saving to NAS. Playing it from there with infuse on AppleTV of VLC on PC
Does this work? Or must AnyDVD the player?
Or does this „works only“ is just saying that DVDFab & Co won‘t run?
Re: LG-BU40N
#8 Post by Coopervid » Sat Jan 21, 2023 12:02 pm
Your last sentence applies.
escence
Re: LG-BU40N
#9 Post by escence » Sat Jan 21, 2023 12:13 pm
Thanks. Considering the Verbatim then.
