Post by RESET_9999 » Wed Jan 18, 2023 2:55 pm
Videoman wrote: Wed Jan 18, 2023 1:26 pm I like the output to be:
- DoVi P8.1 video file
- All input audio files untouched/passthrough
- All input subtitles untouched/passthrough
- Muxed together in a MKV-container
Thank you in advance.
Edit the bat file at line 22 -----> "set MUX=NO"
and line 19 ----> "set container=MKV"
then at the end of the workflow 4-2, you will have the option to mux any audio/sub you want in mkvtoolnix.
yossSP wrote: Tue Jan 17, 2023 4:47 pm After a few more tests, the definitive code to detect spanish tracks is the next one:
if "%spanish%"=="YES" set lang=Spanish& set langDG=spa& set lmp4=es-ES& set lmkv=es
sw5163 wrote: Tue Jan 17, 2023 5:41 pm https://www.audiosciencereview.com/foru ... 51/page-14
I think you can get "Fixed" eac3 atmos from TrueHD atmos now, if you somehow have Dolby Encoding Engine and Dolby Reference Player.
thanks guys! :)
I'm trying to install the script but I can't find a place to get the tools folder. Without it I keep getting "The system cannot find the path specified". Any ideas? @RESET_9999
Yes I wont share the tools pack anymore.
@New dovi_script users, PM to get info on where to get the tools.
fervidace
Post by fervidace » Wed Jan 18, 2023 11:56 pm
anyone know how to get the tools for the dovi scripts? I cant find reference on where to get them anywhere. i would pm @RESET_9999 but im new to the forum and cant send PMs
ragico
Post by ragico » Thu Jan 19, 2023 2:52 pm
@quietvoid
Please can you share your Kodi 20 build?
Many thanks
quietvoid
Post by quietvoid » Thu Jan 19, 2023 5:54 pm
ragico wrote: Thu Jan 19, 2023 2:52 pm @quietvoid
Many thanks
I don't have any new one as my latest added on the fly DoVi converting for profile 7, FEL.
It's v21 though, and not really ready.
danbez
Post by danbez » Thu Jan 19, 2023 6:32 pm
quietvoid wrote: Thu Jan 19, 2023 5:54 pm
Many thanks
Can you share more details about the plan for this conversion, @quietvoid. It sounds really interesting. Are you using DoViBaker to achieve that on-the-fly conversion of FEL?
quietvoid
Post by quietvoid » Thu Jan 19, 2023 8:52 pm
danbez wrote: Thu Jan 19, 2023 6:32 pmCan you share more details about the plan for this conversion, @quietvoid. It sounds really interesting. Are you using DoViBaker to achieve that on-the-fly conversion of FEL?
No, only the RPU metadata is converted to profile 8.1.
This is mostly useful for people who can't play profile 7 FEL (FireTV devices show a blank screen).
I'm not sure of other useful scenarios, other than maybe stability for other devices.
ragico
Post by ragico » Thu Jan 19, 2023 11:37 pm
Many thanks
Thanks. When ready, pls share your 21 build.
danbez
Post by danbez » Fri Jan 20, 2023 12:47 am
quietvoid wrote: Thu Jan 19, 2023 8:52 pm No, only the RPU metadata is converted to profile 8.1.
I see. Thanks for the explanation!
NiCE77
Post by NiCE77 » Fri Jan 20, 2023 7:51 am
Many thanks
Can this conversion code under Kodi be found in one of the github repos?
quietvoid
Post by quietvoid » Fri Jan 20, 2023 1:43 pm
NiCE77 wrote: Fri Jan 20, 2023 7:51 amCan this conversion code under Kodi be found in one of the github repos?
https://github.com/quietvoid/xbmc/tree/libdovi_build
Edworld
Post by Edworld » Fri Jan 20, 2023 5:42 pm
RESET_9999 wrote: Thu Jan 12, 2023 4:35 pm
Edworld wrote: Thu Jan 12, 2023 4:32 am I ran the tool using 4-3 once with DD+ and once without, and I get no audio with BTTF. The video does play in Dolby Vision.
Your input must have lossless audio(THD or DTS) i think. Also , no need to convert DDP audio for the x800m2.
Is there alternative way to have audio work? My makemkv only has one audio track
Post by RESET_9999 » Fri Jan 20, 2023 6:16 pm
Edworld wrote: Fri Jan 20, 2023 5:42 pm Is there alternative way to have audio work? My makemkv only has one audio track
you can disable the muxing at line 21 but later today i will post a new version that can mux all the audio/sub from the input (will only be for MKV though, tsmuxer is much more complicated)
sw5163
Post by sw5163 » Sat Jan 21, 2023 10:30 am
sw5163 wrote: Tue Jan 17, 2023 5:41 pm I would also like to ask if there is a way to merge 12 single channel WAV files into 7.1.4 multi-channel PCM or WAV.
I tried FFmpeg's amerge but I don't know how to merge the over head channel.
To be honest, I don't know anything about audio encoding, and I have no idea what I'm doing.
Feel free to test this 7.1.4.wav on ATV or QuickTime.
5.1.4.wav
I'm still struggling on experimenting FFmpeg's command.
The current command I used to get that file
ffmpeg -i "12_Channel_ID 1.wav" -i "12_Channel_ID 2.wav" -i "12_Channel_ID 3.wav" -i "12_Channel_ID 4.wav" -i "12_Channel_ID 5.wav" -i "12_Channel_ID 6.wav" -i "12_Channel_ID 7.wav" -i "12_Channel_ID 8.wav" -i "12_Channel_ID 9.wav" -i "12_Channel_ID 10.wav" -i "12_Channel_ID 11.wav" -i "12_Channel_ID 12.wav" -c pcm_s32le -filter_complex "join=inputs=12:channel_layout=7.1+TFL+TFR+TBL+TBR:map=0.0-FL|1.0-FR|2.0-FC|3.0-LFE|4.0-BL|5.0-BR|6.0-SL|7.0-SR|8.0-TFL|9.0-TFR|10.0-TBL|11.0-TBR" 7.1.4.wav
The last four "front left, front right, back left, back right" should play in TFL, TFR, TBL, TBR.
ChromePlanet
Post by ChromePlanet » Sat Jan 21, 2023 2:00 pm
Forgive me if I sound like an idiot, but I thought I was already getting Dolby Vision-encoded MKV files from MakeMKV. They are showing up in my Plex Media Server as having both Dolby Vision and HDR-10. This was ripped from MakeMKV with an LG drive to a TS folder for archiving, then used MakeMKV again to rip the TS folder into MKV files.
Screenshot 2023-01-21 at 7.58.35 AM.png (1.85 MiB) Viewed 45357 times
DylanValenti
Post by DylanValenti » Sun Jan 22, 2023 2:28 pm
Anyone know what I'm doing wrong here?
 Choose a mode...
1) MODE.I=  DoVi Convert/Edit/Sync/Inject two inputs (P8 Hybrid maker)
2) MODE.F=  DoVi Fix/Extract/Info/Edit/Verify 1 input (doesn't convert the profile)
3) MODE.H=  DoVi Maker (from HDR10 madVR or HDR10plus)
4) MODE.P=  Profile 7 Input (MKV/BDMV)
5) MODE.B=  Dovi Batch tsMuxer: MKV/MP4 to TS
6) MODE.M=  MIXED: Remover/Measurer/Plotter/Audio/Player and more...
7) MODE.M4= MP4 Workflows
8) Exit
Choice? [1,2,3,4,5,6,7,8]?1
                                         * CHOOSE A WORKFLOW *
1) Workflow.1= Base Layer file + ST P5/P8/P7 DoVi file (can also mux and convert audio)
2) Workflow.2= Batch convert/inject to Profile 8 up to 13 Profile 5 videos + MUX
3) Workflow.3= back to the main menu
Choice? [1,2,3]?1
A subdirectory or file C:\Users\dylanvalenti\Desktop\Script_Stuff\TEMP_folder already exists.
-- This workflow inject / convert / edit DV from any P5/P8/P7 source to an HDR10 BL
-- Can do BL + P5_DV / BL + P8_DV / BL + P7_DV and the output will always be Profile 8
-- Can Crop, Edit L5/L6/min.max_pq and Resync
-- If selected, it converts THD(if present) to THD+ac3 and lossless audio to DDP(can be disable)
-- Will mux to TS if you decide to convert the audio.(can be disable)
-- Input can be MKV/TS/M2TS/MP4/HEVC/H265/RPU/XML
  Drag and drop an HDR10 file(BL)(MKV/TS/M2TS/HEVC/H265)and press enter...
"Z:\DV Hybrid Projects\Baby_Driver\Baby_Driver_HDR10.hevc"
  Drag and drop a Dolby Vision file (RPU/XML/MKV/MP4/TS/M2TS/HEVC/H265) and press enter...
"Z:\DV Hybrid Projects\Baby_Driver\Baby_Driver_DV.hevc"
  Do you want to re-sync the RPU? choices are duplicate=d or remove=r and/or press enter...
  Do you want to edit L6 and source max/min_pq... y or n ? (Default=n) and/or press enter...
y
mkvmerge v71.1.0 ('Fortitude') 64-bit
'Z:\DV Hybrid Projects\Baby_Driver\Baby_Driver_DV.hevc': Using the demultiplexer for the format 'HEVC/H.265'.
'Z:\DV Hybrid Projects\Baby_Driver\Baby_Driver_DV.hevc' track 0: Using the output module for the format 'HEVC/H.265 (unframed)'.
The file 'C:\Users\dylanvalenti\Desktop\Script_Stuff\TEMP_folder\1.mkv' has been opened for writing.
'Z:\DV Hybrid Projects\Baby_Driver\Baby_Driver_DV.hevc' track 0: Extracted the aspect ratio information from the video bitstream and set the display dimensions to 3840/2160.
Progress: 0%
The cue entries (the index) are being written...
Multiplexing took 0 seconds.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'C:\Users\dylanvalenti\Desktop\Script_Stuff\TEMP_folder\temp.vid.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Reordering metadata... Done.
  Do you want to crop RPU... y or n ? (Default=n) and/or press enter...
        * INPUT INFO *
--> L5 Left offset: L5_is_missing_you_should_edit...
--> L5 Right offset: L5_is_missing_you_should_edit...
--> L5 Top offset: L5_is_missing_you_should_edit...
--> L5 Bottom offset: L5_is_missing_you_should_edit...
--> DoVi Profile: 8
--> L2 trims: YES (100nits)
--> DoVi source min_pq: 50 nits
--> DoVi source max_pq: 4000 nits
--> HDR10 BL input MDL: "min: 0.0050 cd/m2, max: 4000 cd/m2"
  Manual or Auto L5... a or m ? and/or press enter...
m
  Set the left border... choose a number and press enter...
0
  Set the right border... choose a number and press enter...
0
  Set the top border... choose a number and press enter...
276
  Set the bottom border... choose a number and press enter...
276
Parsing RPU file...
Exporting metadata...
Done.
[{"dovi_profile":8
Error: unknown field `length`, expected one of `mode`, `remove_cmv4`, `remove_mapping`, `min_pq`, `max_pq`, `active_area`, `remove`, `duplicate`, `scene_cuts`, `level6`, `level9`, `level11`, `level255`, `source_rpu`, `rpu_levels` at line 5 column 12
