kingdom of heaven blu-ray extended version
phillip9
#1 Post by phillip9 » Wed Jan 18, 2023 5:55 pm
I have the kingdom of heaven blu-ray with extended versions.
I am able to get the theatrical version created using makeMKV, but i am having problems with both the extended versions on the blu-ray.
while trying to backup the extended versions, the progress in makemkv will continue to grow from 1-hour to 3-hours and i've seen it go up to 17-hours. i've only let it run for about 1.50 hours before I cancelled it showing over 17-hours to finish.
I've made other blu-ray .mkv files and i've re-made the theatrical version several times with no problems, so I know my SSD, makeMKV and my computer are working fine.
thank you
Here is a link to the dump file for one of the extended versions on the blu-ray that did not work.
