J392191
Post
by J392191 » Sun Feb 02, 2020 5:52 am
I was ripping the Blueray disc "Twelve (2019)", and the ripping wouldn't complete, and get stuck at 2 seconds remaining.
MakeMKV v1.14.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Jake/MakeMKV_log.txt
AACS directory not present, assuming unencrypted disc
File 00000.m2ts was added as title #0
Saving 1 titles into directory L:/Videos/TWELVE ISO BDR
AV synchronization issues were found in file 'L:/Videos/TWELVE ISO BDR/title.mkv' (title #1)
AV sync issue in stream 1 at 0:00:00.026 with duration of 5.333ms : encountered overlapping frame, audio skew is +5.333ms
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '10989600768'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '10989600768'
DEBUG: Code 3221225628 at ]8PztK'0td`)P05'q8:29394758
DEBUG: Code 100864261 at ]8PztK'0td`)P05'q8:29394758
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:29395011
DEBUG: Code 0 at N.*jR!M0zLg3p,94*?XT:29394068
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:29394459
DEBUG: Code 5366016 at 0#09wVinY17cV#\_v,qo:29393286
DEBUG: Code 0 at a\;2X|KY0-z5BQ^r{QzKS:213136608
DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:29394022
DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:29404257
DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:29404763
DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:213139759
DEBUG: Code 0 at *~hnCI|G[w/I^^d}:29395908
DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:213132698
DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:213132146
DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:29393769
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 0 to file L:/Videos/TWELVE ISO BDR/title.mkv
Encountered 25 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
MakeMKV v1.14.7
Grauhaar
Post
by Grauhaar » Sun Feb 02, 2020 6:18 pm
Not an original disc ..?
Good Luck
Useful MakeMKV links:
FAQs -
Debug Log -
Buy -
Expiration of beta key
Post
by Woodstock » Sun Feb 02, 2020 11:13 pm
Your drive said it could not read a sector, then set about trying REALLY HARD to do it. While doing that, the operating system thought it was off-line.
If the drive is a USB drive powered by the USB cable, this can also be caused by the drive spinning too fast for the available power; it powers down, resets, and comes back on line.
khilzinger
Post
by khilzinger » Tue Jan 17, 2023 11:32 pm
I had the same issue. I got two different copies from Amazon, sealed in plastic wrap. I tried both my Blu-Ray drives with the latest version of MakeMKV and I even tried running it as an administrator. I get the following error:
Error 'Internal error - Operation result is incorrect (232)' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '21474791424'
They all stop at the same file size in Windows, too: 19,005,440 KB
Post
by Woodstock » Wed Jan 18, 2023 2:16 am
Sounds like an USB external drive running out of power. Unless it's stopping at the SAME point, rather than where the drive just HAPPENS to hit a speed that the power from the USB port won't support.
A lot of those drives require more power than non-powered hub can handle. The faster they go, the closer to the limit you get.
khilzinger
Post
by khilzinger » Wed Jan 18, 2023 2:48 am
I assure you that power is not an issue. I have a newer laptop and I tried both a dual-USB A cord with both USB cords connected as well as a USB-C cable for two different drives I have. I rip discs all the time with these drives. I even tried it on another computer with an external USB hub with three dedicated power-only USB ports.
I ripped Black Adam 4k, Sing Blu-Ray, and Whiplash 4K on this drive yesterday. It failed with Twelve. I reordered Twelve and tried the new disk. The rip breaks at the same place on the new disk, about 10 seconds from the end, I guess as it is finishing up the read to close the file. It ran at 4.7x - 5.6x the whole time without issue. It's like it does not like this disk for some reason. It is just like what happened with the original post. It goes fine and then it is like it hits a cliff. Always the same spot. Always the same file size.
The disc is really dark as far as the side where the data is.
MATWorX32
Post
by MATWorX32 » Wed Jan 24, 2024 11:21 am
I had the same issue. (I'm using MakeMkv Version 1.17.6.)
Error 'Internal error - Operation result is incorrect (232)' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '23977064448'
[Original]
File size: 24,345,864 KB
Streaming: 6:29:29
However, in the last few seconds an error occurs.
The error always occurs in the same place (about 23GB+).
Is there something wrong with MakeMkv due to the file size or streaming length?
Is it a 20GB limit?
Is it a 6-hour limit?
Does anyone have any information about this error?
Post
by dcoke22 » Sat Jan 27, 2024 3:48 pm
I assume you're not trying to rip the movie
Twelve (2019) that others have referenced in this thread.
MakeMKV does not have a 20GB limit. UHDs and lots of blu-rays are way bigger than 20GB. I'm not aware of a 6 hour limit, but I've never tried to rip a title that's 6 hours long.
Are you trying to rip directly from the disc? What happens if you make a decrypted backup of the disc first, then create a .mkv of that title from the backup?
MATWorX32
Post
by MATWorX32 » Tue Jan 30, 2024 4:45 am
Thanks for the information.
Surely, I'm not ripping the movie Twelve (2019).
However, I ran into a similar error, so I asked for information here.
And I got that there is no limit of 20GB. Thanks.
I'm trying to rip directly from the disc.
The disc was created by the following route:
(1) TV HDD to PC HDD (stream length is 6 hours more)
(2) PC HDD to BD drive on PC (BD-RW disc)
(3) BD-RW disk to PC HDD with decrypt by using MakeMKV
As for "creating a decrypted backup...", it is a great proposal, but I don't know how to do it, so I haven't tried it.
By the way, this disc could be ripped to the end with DVDFab Passkey.
So, it doesn't seem like there's a problem with the disc.
I'll try different things with other streams.
Thank you for your kindness.
