Asus BW16D-1HT FW v 3.11
carrpet
#1 Post by carrpet » Tue Jan 17, 2023 9:59 am
Hi there
I have just bought a new Asus BW16D-1HT drive and it has latest FW v3.11 installed and I don't think there is yet an MK version of this ?
SDFtool recognises the FW as encrypted but will not install v3.10MK.
Please advise on a way forward. Thanks in advance !
carrpet
Re: Asus BW16D-1HT FW v 3.11
#2 Post by carrpet » Tue Jan 17, 2023 10:04 am
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLLMB2J1056
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 60
#3 Post by Billycar11 » Tue Jan 17, 2023 10:45 am
have a flasher for that ready to go if you want it. your doing it correctly not sure why its not working email below for flasher
#4 Post by Coopervid » Tue Jan 17, 2023 11:25 am
carrpet wrote: Tue Jan 17, 2023 9:59 am Hi there
If it's attached via USB try it on SATA.
carrpet
#5 Post by carrpet » Tue Jan 17, 2023 2:10 pm
It's attached via SATA
audiom3
#6 Post by audiom3 » Tue Jan 17, 2023 5:36 pm
I just did one of these a few months back while connected via USB (OWC Mercury Pro enclosure). Did you check the little box on the left (I believe it's called "Include Boot Loader?")?
reifenkauer
#7 Post by reifenkauer » Wed Jan 18, 2023 4:53 pm
Hi, I just attempted to flash one of these drives on Linux using the instruction given here.
I.e., I executed
sudo makemkvcon f -f sdf_00000096.bin -d /dev/sr0 rawflash -i mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Even though the operation allegedly finished successfully, makemkv says after a power cycle:
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLLMB382211
Is this drive simply not supported at the moment?
#8 Post by MartyMcNuts » Wed Jan 18, 2023 8:02 pm
reifenkauer wrote: Wed Jan 18, 2023 4:53 pm Hi, I just attempted to flash one of these drives on Linux using the instruction given here.
I.e., I executed
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
3.11 is encrypted so add enc after rawflash.
reifenkauer
#9 Post by reifenkauer » Thu Jan 19, 2023 11:05 am
MartyMcNuts wrote: Wed Jan 18, 2023 8:02 pm 3.11 is encrypted so add enc after rawflash.
That seems to have done the trick, thanks! :D
Just for completeness sake, this is the command that worked:
sudo makemkvcon f -f sdf_00000096.bin -d /dev/sr0 rawflash enc -i mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
