Asus BW16D-1HT FW v 3.11
Hi there
I have just bought a new Asus BW16D-1HT drive and it has latest FW v3.11 installed and I don't think there is yet an MK version of this ?
SDFtool recognises the FW as encrypted but will not install v3.10MK.
Please advise on a way forward. Thanks in advance !
Re: Asus BW16D-1HT FW v 3.11
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLLMB2J1056
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 60
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
have a flasher for that ready to go if you want it. your doing it correctly not sure why its not working email below for flasher
If it's attached via USB try it on SATA.carrpet wrote: ↑Tue Jan 17, 2023 9:59 amHi there
It's attached via SATA
I just did one of these a few months back while connected via USB (OWC Mercury Pro enclosure). Did you check the little box on the left (I believe it's called "Include Boot Loader?")?
reifenkauer
Hi, I just attempted to flash one of these drives on Linux using the instruction given here.
I.e., I executed
Even though the operation allegedly finished successfully, makemkv says after a power cycle:
Is this drive simply not supported at the moment?
I.e., I executed
sudo makemkvcon f -f sdf_00000096.bin -d /dev/sr0 rawflash -i mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.binCode: Select all
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLLMB382211
No disc inserted-
3.11 is encrypted so add enc after rawflash.reifenkauer wrote: ↑Wed Jan 18, 2023 4:53 pmHi, I just attempted to flash one of these drives on Linux using the instruction given here.
I.e., I executed
Even though the operation allegedly finished successfully, makemkv says after a power cycle:Code: Select all
Is this drive simply not supported at the moment?Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: ASUS Product: BW-16D1HT Revision: 3.11 Serial number: KLLMB382211 Firmware date: 2120-12-01 17:59 Bus encryption flags: 1F LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959 No disc inserted
reifenkauer
That seems to have done the trick, thanks!
Just for completeness sake, this is the command that worked:
sudo makemkvcon f -f sdf_00000096.bin -d /dev/sr0 rawflash enc -i mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
