Asus BW16D-1HT FW v 3.11
carrpet
Post by carrpet »
Hi there
I have just bought a new Asus BW16D-1HT drive and it has latest FW v3.11 installed and I don't think there is yet an MK version of this ?
SDFtool recognises the FW as encrypted but will not install v3.10MK.
Please advise on a way forward. Thanks in advance !
carrpet
Re: Asus BW16D-1HT FW v 3.11
Post by carrpet »
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLLMB2J1056
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 60
have a flasher for that ready to go if you want it. your doing it correctly not sure why its not working email below for flasher
carrpet wrote: Tue Jan 17, 2023 9:59 am Hi there
If it's attached via USB try it on SATA.
carrpet
Post by carrpet »
It's attached via SATA
audiom3
Post by audiom3 »
I just did one of these a few months back while connected via USB (OWC Mercury Pro enclosure). Did you check the little box on the left (I believe it's called "Include Boot Loader?")?
reifenkauer
Post by reifenkauer »
Hi, I just attempted to flash one of these drives on Linux using the instruction given here.
I.e., I executed
sudo makemkvcon f -f sdf_00000096.bin -d /dev/sr0 rawflash -i mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Even though the operation allegedly finished successfully, makemkv says after a power cycle:
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLLMB382211
Is this drive simply not supported at the moment?
reifenkauer wrote: Wed Jan 18, 2023 4:53 pm Hi, I just attempted to flash one of these drives on Linux using the instruction given here.
I.e., I executed
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
3.11 is encrypted so add enc after rawflash.
reifenkauer
MartyMcNuts wrote: Wed Jan 18, 2023 8:02 pm 3.11 is encrypted so add enc after rawflash.
That seems to have done the trick, thanks! :D
Just for completeness sake, this is the command that worked:
sudo makemkvcon f -f sdf_00000096.bin -d /dev/sr0 rawflash enc -i mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
