Hash check error workaround?
jedidarrick
#1 Post by jedidarrick » Tue Jan 17, 2023 1:07 am
I started ripping titles using MakeMKV onto my Mac after flashing my Drive. I ripped two discs today, tried to get a third one, and it was unable to rip the third title due to something called an "M2TS hash check error." I tried ripping the same title twice and it gave me that error twice. This third disc was from the same boxset as the other two titles, so I am not sure why it is giving me this issue. Is there a workaround for this, or should I just let my UHD Drive rest for a while?
Re: Hash check error workaround?
#2 Post by Billycar11 » Tue Jan 17, 2023 1:48 am
That's a read errors related to the disc or drive
The usual steps are
Clean the disc with a damp lint free microfiber cloth and dry with another
Replace the disc
Clean the drive by opening it and cleaning lasers with alcohol on something lint free cleaning discs are a joke don't use them
After that replace the drive if none of that works
jedidarrick
#3 Post by jedidarrick » Tue Jan 17, 2023 2:08 am
I'll assume it's an issue with the disc, as my Drive is relatively new and I've only ripped two films so far. Thanks for the advice!
