Hi, ive ripped hundreds of disc with MakeMKV and never had this error before
Ive come to rip the Black Adam 4k and i'm getting the following error message:
Volume Key is unknown for this disc - video cannot be decrypted
Backup failed
Ive ripped the standard 1080p blu ray disc that came with it and that works just fine.
Has anyone else had a problems with this disc and do I need to wait for MakeMKV to prepare a volume key?
Thanks in advance
Black Adam UHD Disc Error
Re: Black Adam UHD Disc Error
UHD FAQ
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
Send in the dump file that was created so the volume key can be generated.markjames81 wrote: Mon Jan 16, 2023 7:45 pm Hi, ive ripped hundreds of disc with MakeMKV and never had this error before
Backup failed
Thanks in advance
ictbydesign
Ripped OK yesterday.
