Black Adam UHD Disc Error
markjames81
Post by markjames81 »
Hi, ive ripped hundreds of disc with MakeMKV and never had this error before
Ive come to rip the Black Adam 4k and i'm getting the following error message:
Volume Key is unknown for this disc - video cannot be decrypted
Backup failed
Ive ripped the standard 1080p blu ray disc that came with it and that works just fine.
Has anyone else had a problems with this disc and do I need to wait for MakeMKV to prepare a volume key?
Thanks in advance
Re: Black Adam UHD Disc Error
Post by d00zah »
UHD FAQ
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
markjames81 wrote: Mon Jan 16, 2023 7:45 pm Hi, ive ripped hundreds of disc with MakeMKV and never had this error before
Backup failed
Thanks in advance
Send in the dump file that was created so the volume key can be generated.
ictbydesign
Post by ictbydesign »
Ripped OK yesterday.
