Universal Soldier 4K
nodnil
Post by nodnil »
I could not find any post on this, so I decided to create one. I have a 4K blu ray for Universal Soldier (1992). There appears to be two options for the movie file itself (00009.mpls and 00016.mpls). I have made the MKV file for both and put them on Jellyfin to watch, but neither work. I re-did it to make sure there was not possibly an error in the file itself, but it still does not work. I was wondering if anyone else has experienced this and what the possible solution may be? I included what MakeMKV shows me once I insert in the disc. This is from LionsGate and is the only disc I have had an issue with, so I decided to look online to see if others had issues with other LionsGate discs but did not see anything. Any help would be appreciated!
universal soldier.jpg (91.9 KiB) Viewed 3996 times
sephirothkefka
Re: Universal Soldier 4K
Post by sephirothkefka »
They are both the same file its just one has the chapter info and one doesn't. Some other UHD's can be similar from time to time
