I'm getting a black screen after creating ts files with DoviScript 1.7.1 using the batch option and with the ts files my Sony x800m2 freezes.
I also have an error easyaudioencorer: safe_fopen: createfileW failed:2
The movies are 1917 and BTTF, both of them with Dolby Vision and HDR10+ are in a makemkv file
Thanks for the support
Edworld
Yes, it's a known issue with Single-track dual-layer file.Edworld wrote: Wed Jan 11, 2023 9:55 pm I'm getting a black screen after creating ts files with DoviScript 1.7.1 using the batch option and with the ts files my Sony x800m2 freezes.
Use 4-3 instead and make a dual-track dual-layer file.
normal when you encode 7.1 audio with EAE.I also have an error easyaudioencorer: safe_fopen: createfileW failed:2
you can ignore it but dont close the window before the audio conversion is done.
Edworld
I ran the tool using 4-3 once with DD+ and once without, and I get no audio with BTTF. The video does play in Dolby Vision.RESET_9999 wrote: Wed Jan 11, 2023 10:20 pmYes, it's a known issue with Single-track dual-layer file.Edworld wrote: Wed Jan 11, 2023 9:55 pm I'm getting a black screen after creating ts files with DoviScript 1.7.1 using the batch option and with the ts files my Sony x800m2 freezes.
lexyz
And what if to force LLDV on shield (in dev settings)?RESET_9999 wrote: Thu Jan 05, 2023 11:36 pm no effect on the shield and C2.
MP4 versions here: https://drive.google.com/drive/u/1/fold ... fx6vRYDEfs
Your input must have lossless audio(THD or DTS) i think. Also , no need to convert DDP audio for the x800m2.Edworld wrote: Thu Jan 12, 2023 4:32 am I ran the tool using 4-3 once with DD+ and once without, and I get no audio with BTTF. The video does play in Dolby Vision.
I looked at this a couple of weeks ago and couldn't find that specific settings. How is it called exactly?
Seraphimon956
Hi, I have got a question about the behavior of the X700 when using the bdmv mode to play Dolby vision and truehd atmos content. I use tsmuxer (latest nightly) to create a bdmv folder structure from the original ripped UHD disk. Then I put the two folders, BDMV and CERTIFICATE, at the USB drive root of my external HDD. But when I try to play the bdmv folder using the x700 and opening the AVCHD virtual folder (I assume the x700 itself creates it every time in order to open the bdmv folder), only the dolby vision label appear on the right corner of my lg cx. I can confirm that FF/RW (even for +3 hours movies), chapter list, and forced subtitle indeed work as per the Dolby_Vision_Stuff table (this trick also prevents entirely the annoying green/purple bug when reproducing multiple DV m2ts). But the Dolby atmos label does not trigger (I can confirm this by opening the TV info tab on my LG cx), even though the audio is being played regularly and the player reports that the audio track is Dolby truehd (has it been downgraded or only the AC3 core is actually played? Maybe someone can shed some light on this matter, I am so confused
). The strange fact is that if I try opening the 0000.m2ts file directly, without putting the bdmv folder at the USB drive root, Dolby atmos label and Dolby vision label both show up in the top right corner, although FF/RW is blocked. Furthermore, it seems that the maximum limit for audio tracks and subtitles is 8 when playing m2ts files, even if the latter have been muxed with tsmuxer. So, with ten audio tracks and ten subtitles, only the first eight will be read and the others will be simply ignored by the player (the cycle starts again from subtitle 1 or from audio track 1). I hope someone here can clarify this issue, could be just a bug of the TV not recognizing the atmos track, although I am really not sure about it.
lexyz
LLDV (Bravia XF90)
Shield TV - visible picture adjustments after 1000 nit for all versions P5/P8 old and new
Zidoo Z9X - only P8 works, P5 - no adjustments (forces VS10 and Auto HDR modes tested)
UBP-X700 - this one is extremely interesting! only P8 old works but without any visible changes up to 4000 nit
I suppose it just do tonemapping to 4k ignoring Target Max PQ value from EDID
In that case some movies indeed will be darker in DV on this player like this https://slow.pics/c/Eyy9YjPX and all the fuss about Sony's dim DV from external sources make sense now
btw could you please make version with MDL and MCLL limited by 1000nit?
Shield / Settings / Device Preferences / Developer options / Default to Low Latency Dolby Vision when availableRESET_9999 wrote: Thu Jan 12, 2023 4:35 pm I looked at this a couple of weeks ago and couldn't find that specific settings. How is it called exactly?
Anyway LL11 doesnt work on Shield even in LLDV mode
chronomac
Started using the DoVi_Scripts tool in earnest this week and I have a question about the audio, for converting Profile 7 MKV rips to Profile 8.
When I run the script, I use option 4 (for Profile 7 MKV input) then 2 (for profile 7 rip to profile
and then I drop the file in. Once it reads the file it asks if I want to convert the audio to DDP and I hit N and then N again for editing L5. Using those selections, specifically the one about DDP, will the quality of the original audio track be diminished? I ask because once I converted a full length movie, I checked the old and new files in MediaInfo and while the max bitrates on those audio tracks were the same, the regular bitrate was smaller (from 4,339 kb/s to 64) and the size was smaller (3.62 GB to 54.7 MB). This is a movie with a TrueHD 5.1 track.
I just want to make sure I don't touch the audio much, if at all - I like having a lossless track. The DV conversion seems to work just fine (changing the file to a .ts).
thanks interesting results.lexyz wrote: Thu Jan 12, 2023 5:11 pmLLDV (Bravia XF90)
UBP-X700 - this one is extremely interesting! only P8 old works but without any visible changes up to 4000 nit![]()
Did you remux the file to TS? Sometimes my x800m2 gives me "fake" DV with mp4 files.UBP-X700 - this one is extremely interesting! only P8 old works but without any visible changes up to 4000 nit![]()
yep, this is why I sold my Zidoo player. Many times the RPU didn't work at all and it seems to be random.Zidoo Z9X - only P8 works, P5 - no adjustments (forces VS10 and Auto HDR modes tested)
more test files:
this one test L2 trim passes: https://drive.google.com/file/d/15iySXK ... share_link
This one compares original DV with generated DV. (this is the reason why the latest version of my script now overwrites L2 when it inject XML.)
https://drive.google.com/file/d/1_PkGF9 ... share_link
it's because MediaInfo reports the AC3 core bitrate and size of a trueHD track. If you demux it, you will see that the size is truly lossless and the same as the original.chronomac wrote: Thu Jan 12, 2023 5:32 pm Started using the DoVi_Scripts tool in earnest this week and I have a question about the audio, for converting Profile 7 MKV rips to Profile 8.
When I run the script, I use option 4 (for Profile 7 MKV input) then 2 (for profile 7 rip to profileand then I drop the file in. Once it reads the file it asks if I want to convert the audio to DDP and I hit N and then N again for editing L5. Using those selections, specifically the one about DDP, will the quality of the original audio track be diminished? I ask because once I converted a full length movie, I checked the old and new files in MediaInfo and while the max bitrates on those audio tracks were the same, the regular bitrate was smaller (from 4,339 kb/s to 64) and the size was smaller (3.62 GB to 54.7 MB). This is a movie with a TrueHD 5.1 track.
When the script is set to mux to TS container , it automatically add a silent 64kbps core to the TrueHD track for bluray player compatibility.
FYI, you dont have to answer "N" to the DDP and L5 questions. You can just press enter to skip it.
chronomac
That's really good to know (that I'm actually getting a lossless audio track). Thanks!RESET_9999 wrote: Thu Jan 12, 2023 11:17 pmit's because MediaInfo reports the AC3 core bitrate and size of a trueHD track. If you demux it, you will see that the size is truly lossless and the same as the original.chronomac wrote: Thu Jan 12, 2023 5:32 pm Started using the DoVi_Scripts tool in earnest this week and I have a question about the audio, for converting Profile 7 MKV rips to Profile 8.
niallobr
I'd like to also ask an audio related question. I'm pretty sure the answer is no, but hey
@RESET_9999 is there any way to use your script and the tools provided to convert TrueHD Atmos -> EAC3 Atmos? It seems impossible to change formats and keep the Atmos data with these tools? I've tried the different audio encoding options without success.
It is still great that your script can convert 7.1 TrueHD to 7.1 EAC3, since ffmpeg still can't do more than 6 channels yet. I guess this is the joy of working with non-licensed software
Thank you very much for your work on the script. It is powerful but also makes things very simple.
Seraphimon956
I have discovered another strange bug (?). Apparently, when one plays the .m2ts created with tsmuxer, with Dolby vision FEL content (profile 7 double layer), my LG cx does show the label for atmos and dolby vision, but the player itself says that the content is 4k/24p HDR. The same does not apply when you play the bdmv at the root of the USB external drive by pressing the avchd virtual folder; in that case both the player and the TV display the Dolby Vision label. But the problem of the downgrade of the Atmos track remains and now I am pretty sure of it since the difference is audible even by reproducing atmos content with the TV internal speakers: the Atmos track is clearer and slightly louder. I hope someone has fresh info on this problem, I literally searched everywhere but nobody seems to have noticed the atmos downgrade bug.Hi, I have got a question about the behavior of the X700 when using the bdmv mode to play Dolby vision and truehd atmos content. I use tsmuxer (latest nightly) to create a bdmv folder structure from the original ripped UHD disk. Then I put the two folders, BDMV and CERTIFICATE, at the USB drive root of my external HDD. But when I try to play the bdmv folder using the x700 and opening the AVCHD virtual folder (I assume the x700 itself creates it every time in order to open the bdmv folder), only the dolby vision label appear on the right corner of my lg cx. I can confirm that FF/RW (even for +3 hours movies), chapter list, and forced subtitle indeed work as per the Dolby_Vision_Stuff table (this trick also prevents entirely the annoying green/purple bug when reproducing multiple DV m2ts). But the Dolby atmos label does not trigger (I can confirm this by opening the TV info tab on my LG cx), even though the audio is being played regularly and the player reports that the audio track is Dolby truehd (has it been downgraded or only the AC3 core is actually played? Maybe someone can shed some light on this matter, I am so confused). The strange fact is that if I try opening the 0000.m2ts file directly, without putting the bdmv folder at the USB drive root, Dolby atmos label and Dolby vision label both show up in the top right corner, although FF/RW is blocked. Furthermore, it seems that the maximum limit for audio tracks and subtitles is 8 when playing m2ts files, even if the latter have been muxed with tsmuxer. So, with ten audio tracks and ten subtitles, only the first eight will be read and the others will be simply ignored by the player (the cycle starts again from subtitle 1 or from audio track 1). I hope someone here can clarify this issue, could be just a bug of the TV not recognizing the atmos track, although I am really not sure about it.
nekno
I don't have a CX to know how audio is treated, but you're expecting the CX to pass the TrueHD audio through to an audio device via eARC? What does the device say it's decoding? My understanding is that the CX does not have a TrueHD decoder to play back the audio on the TV. The Atmos support is limited to an EAC3 decoder. Supported codecs: AC4, AC3 (Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, WMA, apt-X (refer to manual)Seraphimon956 wrote: Fri Jan 13, 2023 10:38 pm I have discovered another strange bug (?). Apparently, when one plays the .m2ts created with tsmuxer, with Dolby vision FEL content (profile 7 double layer), my LG cx does show the label for atmos and dolby vision, but the player itself says that the content is 4k/24p HDR. The same does not apply when you play the bdmv at the root of the USB external drive by pressing the avchd virtual folder; in that case both the player and the TV display the Dolby Vision label. But the problem of the downgrade of the Atmos track remains and now I am pretty sure of it since the difference is audible even by reproducing atmos content with the TV internal speakers: the Atmos track is clearer and slightly louder. I hope someone has fresh info on this problem, I literally searched everywhere but nobody seems to have noticed the atmos downgrade bug.
I send my video+audio from the X700 through an AVR to a TV, and the AVR plays and decodes and shows the info for TrueHD Atmos when the audio stream is properly muxed with an AC3 core. If you're taking your audio stream from the UHD BD as you say, then you should already have the AC3 core in your audio stream when you remux to BDMV. If you're going through some other intermediate step, you need to first remux your TrueHD stream with an AC3 core before remuxing the DTDL HEVC files and thd+ac3 file to BDMV.
The X700 won't play DV7 from m2ts in my experience, you have to use a BDMV folder from USB. The X700 is reporting HDR instead of DV because it isn't applying DV, it's just playing back the HDR10 BL.
So for m2ts, you'd have to convert DV7 FEL to DV8.1 and lose the benefit of the full EL.
For DV7 MEL/FEL, I use BDMV format for the best playback experience and max quality, and I get TrueHD Atmos audio.
For DV8, I use m2ts format streamed from network or USB and can also get TrueHD Atmos audio.
nop i dont think so. If it ever happens it will be from there: https://forum.doom9.org/showthread.php?t=184364niallobr wrote: Fri Jan 13, 2023 10:41 am @RESET_9999 is there any way to use your script and the tools provided to convert TrueHD Atmos -> EAC3 Atmos? It seems impossible to change formats and keep the Atmos data with these tools? I've tried the different audio encoding options without success.
the best you can do i think (but never tried) is to take the metadata from an existing DD+ atmos 768kbps track and encode a new 1536kbps DD+ atmos track in DEE + cavernize using the TrueHD and DDP track metadata.
You just have to remux the original m2ts to a new m2ts(or ts) with tsmuxer to get DV. Your new m2ts will have the proper flag:nekno wrote: Sun Jan 15, 2023 9:33 am The X700 won't play DV7 from m2ts in my experience, you have to use a BDMV folder from USB. The X700 is reporting HDR instead of DV because it isn't applying DV, it's just playing back the HDR10 BL.
Format : MPEG-TS
File size : 63.5 GiB
Duration : 1 h 50 min
Overall bit rate mode : Variable
Overall bit rate : 82.0 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video #1
Menu ID : 1 (0x1)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 227 cd/m2
Video #2
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 6
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
