Can you still flash new drives like ASUS BW-16D1HT
Patrickjp
#1 Post by Patrickjp » Tue Aug 16, 2022 8:41 am
The reason Im asking Is because I heard In a video that manufacturers or
the people who make the optical drives are trying to make it so you cant
change the firmware or something like that. Im thinking of buying the ASUS
BW-16D1HT from amazon will I be able to flash it still?
Re: Can you still flash new drives like ASUS BW-16D1HT
#2 Post by Billycar11 » Tue Aug 16, 2022 12:02 pm
yes
whoever made that video is lying we can still flash them
kubuntufan01
#3 Post by kubuntufan01 » Thu Jan 12, 2023 12:52 am
Yes you can still flash them. :D I do have a few questions though and I think the thread topic this should be under is locked.
I flashed the drive successfully but am I missing something? Did me flashing it using the 'enc' just make the drive where it's unlocked and
capable of being flashed with different firmware? I did read the thread on libredrives...what they are etc. Where do I find the 'DE' firmware for my drive?
I also read the thread about windows gui for flashing. I only use Kubuntu which is a fork off Ubuntu distro.
#4 Post by Billycar11 » Thu Jan 12, 2023 2:03 am
kubuntufan01 wrote: Thu Jan 12, 2023 12:52 am Image
you didnt flash it successfully as you used enc when you should not have do it again without that and it should work.
kubuntufan01
#5 Post by kubuntufan01 » Thu Jan 12, 2023 2:17 am
user@Node-11:~$ sudo -i
[sudo] password for user:
root@Node-11:~# cd /home/user/
root@Node-11:/home/user# makemkvcon f -v -f sdf_00000096.bin -d /dev/sr0 rawflash -i ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Loaded SDF.bin version 0x96
Reading input file ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Current Drive ID: ASUS_BW-16D1HT_3.10_211901041014_KLZL9PA3508
yes
 100% Operation finished
Done successfully
Command produced 0 file(s)
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLZL9PA3508
Bus encryption flags: 1F
Highest AACS version: 18
Firmware version: 3.10
Thanks!! :D So the process would be the same to use the 'DE' firmware?
root@Node-11:/home/user# makemkvcon f -v -f sdf_00000096.bin -d /dev/sr0 rawflash -i DE_ASUS_BW-16D1HT_3.02.bin
#6 Post by Billycar11 » Thu Jan 12, 2023 2:33 am
kubuntufan01 wrote: Thu Jan 12, 2023 2:17 am
yes
Done successfully
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
yes now you are good as it says reenabled.
yes same thing now to go to DE if you wanted but you did have to go to mk first.
