Old .iso of The Lion King fails
Razorax
Post by Razorax » Sat Apr 30, 2011 7:38 pm
MakeMKV is not able to process the .iso (mounted using magicIso), but my player (WD TV Live) plays it "ok".
normal log wrote:DEBUG: Code 267220 at HGuVpzdLptXOsT'Ddx:29398484
DEBUG: Code 0 at HGuVpzdLptXOsT'Ddx:29402302
DEBUG: Code 0 at HGuVpzdLptXOsT'Ddx:213139759
Title #26 (1:25:16) was skipped due to navigation error
DEBUG: Code 79393 at HGuVpzdLptXOsT'Ddx:29398484
Title #27 (1:24:33) was skipped due to navigation error
Debug log attached.
Navvie
Re: Old .iso of The Lion King fails
Post by Navvie » Sat Apr 30, 2011 7:40 pm
Try just pointing MakeMKV at the ISO.
eg. don't mount it.
Registered user
Linux / Windows 10
Asus BW-16D1HT 3.10MK (disc exploded, taking out my second BW-16D1HT)
Asus BC-12D2HT 3.11MK
LG BH16NS40 flashed to WH16NS60 1.03
LG GGC-H20L 1.03
Pioneer BDR-205 GENE
Razorax
Post by Razorax » Sat Apr 30, 2011 7:42 pm
Tried that as the first effort.
MagicISO was as a last resort.
Same result though.
EDIT: But as the log indicates, the ISO is pretty fc*ked up... never the less, it plays :D
VLC even has menus and all... Must be some sort of Disney Copy Protection from back in the 1990ies...
setarip_old
Post by setarip_old » Sun May 01, 2011 7:04 am
Hi!
Since you seem to be aware that the .ISO image file is "less than perfect", just use your original, commercial "Lion King" disc (instead of your old .ISO image file) as your source for MakeMKV...
Razorax
Post by Razorax » Sun May 01, 2011 7:24 am
Good idea, one I would have used if it hadn't been for my 2? yr old girl, and her less than perfect... eh... cleaning of the disc :-(
Just assumed MakeMKV wanted to support as much as possible, and since VLC knows how to handle it, I assumed it was on purpose from Disneys PoV that the .iso is "garbled".
EDIT: But, nvm then, DVDFab knows how to handle it...
Post by mike admin » Fri May 06, 2011 1:46 pm
Razorax wrote:Good idea, one I would have used if it hadn't been for my 2? yr old girl, and her less than perfect... eh... cleaning of the disc :-(
Still, please send all IFO files from the disc per instructions at http://www.makemkv.com/faq/item/8/catid/6 .
Razorax
Post by Razorax » Sun Jun 19, 2011 7:13 pm
Attached is the IFOs.
