DVD read fail: DEBUG: Code 0
FLmusicDir
Post by FLmusicDir » Tue Jan 10, 2023 6:01 pm
I have a DVD - Captain from Castile - that MakeMKV consistently fails to read. I am using a Mid 2015 MacBook Pro w/OS 12.6 and a Pioneer BDR-XS07U. I have been using the Pioneer drive without incident for the last 3 months.
MKV locks up at the same place no matter what I have tried. I have cleaned the disk; I have played the whole movie with the Apple DVD player app, I update JRE. Not sure what to try next.
The screen info:
MakeMKV v1.17.2 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/mcesarano/MakeMKV_log.txt
Optical drive "BD-RE PIONEER BD-RW BDR-XS07U 1.01 BADL005108UCd" opened in OS access mode.
udf: udf_get_node: bad allocation extension size in udf_node
DEBUG: Code 0 at i|[AoE|0g19n-QG>O:121262992
Using LibreDrive mode (v01.0 id=1534D764B687)
Calculated BUP offset for VTS #0 does not match one in IFO header.
DEBUG: Code 164 at A6J`{yh*d8]Z1s:121273020
Calculated BUP offset for VTS #3 does not match one in IFO header.
DEBUG: Code 2 at A6J`{yh*d8]Z1s:213131755
DEBUG: Code 6 at x6,|(2:VQA7jU0_Rw:213131318
DBG ASSERT: ON{SHfb<CWTk!i+c]%]csk<F&;Xwn4o}KKk at A6J`{yh*d8]Z1s:29402003
Calculated BUP offset for VTS #6 does not match one in IFO header.
DEBUG: Code 118095996 at 'He45{[q-y^5,6lA[]*$o,/:29394183
DEBUG: Code 0 at 'He45{[q-y^5,6lA[]*$o,/:121263590
DEBUG: Code 0 at _%SXZ,ljdE.zAAv}?&ui:29394689
I have attached the MKV Log as well.
Not sure what is failing at this point.
Re: DVD read fail: DEBUG: Code 0
Post by d00zah » Tue Jan 10, 2023 6:20 pm
DVD opening modes - CellWalk, CellTrim, CellFull
Rather than 'auto' (default), some have had luck selecting 'CellTrim' mode.
Preferences > Protection > DVD section pull-down
Worth a try?
FLmusicDir
Post by FLmusicDir » Tue Jan 10, 2023 6:24 pm
Thanks d00zah. I'll give it a try and let you know the results.
FLmusicDir
Post by FLmusicDir » Tue Jan 10, 2023 6:35 pm
d00zah wrote: Tue Jan 10, 2023 6:20 pm DVD opening modes - CellWalk, CellTrim, CellFull
Worth a try?
Thanks, it worked.
