Just felt like throwing this out there, since nobody seems to be talking about it. I was looking for an easy-to-use LibreDrive for quite a while, until I found this manufacturer.
Techpulse120 is an OEM that sells UHD drives on the base of the LG BU40N. Every single drive comes with an unpatched (v1.0) firmware, so no patching/flashing/etc... LibreDrive is literally plug and play, which is amazing. They also have a pretty good customer service. You can buy from them on Amazon or on their own website.
PSA: techpulse120's drives are the best drives for beginners
Johnny_nzt
Ezatoka
Re: PSA: techpulse120's drives are the best drives for beginners
Or, you know, we just could go into our own subforum with sellers and experiences from buyers about them instead of going to somewhere else: viewforum.php?f=20
That's quite expensive. Take the Verbatim. It comes with a Pioneer UHD drive:Johnny_nzt wrote: Mon Jan 09, 2023 2:31 pm Just felt like throwing this out there, since nobody seems to be talking about it. I was looking for an easy-to-use LibreDrive for quite a while, until I found this manufacturer.
https://www.amazon.de/Verbatim-Externer ... 9hdGY&th=1
