Problem Flashing BP55EB40
DonaldFaQ
Re: Problem Flashing BP55EB40
Post by DonaldFaQ »
The BP60N10 FW from the MK Pack don't work for me. The the Hybrid FW from here works fine.
EDIT: The BP60N10 FW from the MK Pack works well if you set the enc button to green.
rvdboom
Post by rvdboom »
Hi, all.
I'm using makemkvcon on linux to flash my drive and it apparently works well. However, the drive reported by makemkvcon keeps the same name and I can't read UHD drives.
Here is the output of makemkvcon for the drive:
root@coyote:~# makemkvcon f -l
Found 1 drives(s)
00: dev_21:4, /dev/sr0, /dev/sr0
  HL-DT-ST_BD-RE_BP55EB40_1.03_212005070924_SIK07M2895606
This is a USB BP55EB40 drive.
I tried flashing several firmware (the MK BP55EB40-NB50 and BP60NB10 one, the hybrid E_LG_BP60NB10), with same results for all:
root@coyote:~# makemkvcon f -d 'dev_21:4' -f /home/richard/tmp/sdf.bin rawflash main -i /home/richard/tmp/DE_LG_BP60NB10_1.00_MK_HBD.bin
Reading input file /home/richard/tmp/DE_LG_BP60NB10_1.00_MK_HBD.bin
Current Drive ID: HL-DT-ST_BD-RE_BP55EB40_1.03_212005070924_SIK07M2895606
DEBUG: Code 117637252 at viMquYt1v=$Gzk%Z~&aQ#/W!W1[^Pbye:213132261
Desktop drive handshake failed with error=0x07030084, trying slim drive handshake...
yes
 100% Operation finished
Done successfully
Is there something I'm doing wrong?
Cheers,
Please try to add the -enc parameter to your command line.
rvdboom
Post by rvdboom »
Tried this (with sdftool):
root@coyote:~# sdftool -d /dev/sr0 rawflash main,enc,slim -i /home/richard/tmp/mk-firmware-pack-20200720/MK/HL-DT-ST/BP55EB40-NB50/HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-NM00800-212005070924.bin
Reading input file /home/richard/tmp/mk-firmware-pack-20200720/MK/HL-DT-ST/BP55EB40-NB50/HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-NM00800-212005070924.bin
Using an USB slim drive handshake
yes
Done successfully
I unplugged the drive and plugged it back just in case it would be needed to take into account the new firmware. I tried to read two UHD disks (Dark crystal, BBC Blue planet II) but no luck. :-(
The flash tool seems to work fine, at least.
For the record, here is the sdftool info on the drive :
root@coyote:~# sdftool -d /dev/sr0 --info
SDF.bin version: 0x0090
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8105:Enabled
8001:Drive platform
:MT1959
8002:Firmware type
8107:Patched (microcode access re-enabled)
8003:Firmware version
:1.03
8005:DVD all regions
8100:Yes
8006:BD raw data read
8100:Yes
8007:BD raw metadata read
8100:Yes
8009:Unrestricted read speed
8100:Yes
[Drive Specific SDF] Embedded Status Message:
8099:Using LibreDrive mode (v%1 id=%2)
:06.3
:EC856CB25912
Identification SDF present
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:BUP3:HL-DT-ST:BD-RE BP55EB40  1.03:NM00800:-
This firmware is not UHD compatible. You now need to cross-flash it. I just don't know how to do it with Linux. This is what Marty said for Windows.
1. Flash the drive to either WP50NB40 (NB50) 1.03-MK or BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the WP50NB40 (NB50) 1.03-MK or BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select either the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box. Whichever one you want to use.
4. Click START
EDIT: I think I found it:
BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
if using command line add "full" after rawflash
rvdboom
Post by rvdboom »
Thanks. How do you see it's not enabled? Is that a particular value in the sdftool --info output?
What you mean enabled? Your firmware is not UHD compatible. You need to cross-flash your firmware to BP60NB10.
rvdboom
Post by rvdboom »
Sorry, I misunderstood.
It worked, this is what I did:
1/ Flash a first time with the MK firmware (viewtopic.php?f=19&t=19113) in full (I suppose to get rid of encryption and flash the boot also) :
# sdftool -d /dev/sr0 rawflash full,enc,slim -i /home/richard/tmp/mk-firmware-pack-20200720/MK/HL-DT-ST/BP55EB40-NB50/HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-NM00800-212005070924.bin
2/ Flash again with the BP60NB10 1.00_HBD hybrid firmware (viewtopic.php?f=16&t=18933):
# sdftool -d /dev/sr0 rawflash slim -i /home/richard/tmp/DE_LG_BP60NB10_1.00_MK_HBD.bin
That did the trick. HBD firmware do not work in full mode, so I guess that's why you need the first step.
Thanks a lot for the help, Coopervid.
You are very welcome! Sorry - couldn't help with the Linux steps but with what had to be done.
