Post by RESET_9999 » Tue Jan 03, 2023 10:25 pm
jlpsvk wrote: Tue Jan 03, 2023 8:53 pm anybody can help with python for dovi_scripts???? i'm stucked on "models" module... can't install because of "references" module not found... and can't install that... pymodels again stuck at "props.references"
I'm guessing you're trying to plot DV (6-2-3) ?
1-Uninstall any python version you have and reboot.
2- get and install python: https://www.python.org/
3- Open a CLI windows and type 1 by 1 all the required modules:
EG:
pip install ijson
lolipeid47 wrote: Tue Jan 03, 2023 6:31 pm thank you but I want also to print the dynamic shots in a json file ? any idea man ;-)
i want it just like you like this https://justpaste.it/47641 but havent found my way yet
2-4 in the script or see: viewtopic.php?p=123221#p123221
ragico wrote: Tue Jan 03, 2023 7:45 pm Welcome back RESET_9999
:D
jlpsvk
Post by jlpsvk » Tue Jan 03, 2023 11:32 pm
RESET_9999 wrote: Tue Jan 03, 2023 10:25 pm
EG:
pip install ijson
yes... 6-2-3
tried that... no luck... :-/ models keeps asking for missing "base", then "props"... both installed ok, but "references" are a showstopper
lolipeid47
Post by lolipeid47 » Wed Jan 04, 2023 1:41 am
ty RESET_1999
your answers helped me tremendously, I'm now fully operationnal 8) :mrgreen:
jayper
Post by jayper » Wed Jan 04, 2023 8:39 am
Thrilled to have you back!
ArArdin
Post by ArArdin » Wed Jan 04, 2023 9:55 am
Good to see you back, RESET_9999 :)
deadchip12
Post by deadchip12 » Thu Jan 05, 2023 3:59 pm
Any update from Sony to fix dolby vision issue on the x700/x800?
ragico
Post by ragico » Thu Jan 05, 2023 4:38 pm
deadchip12 wrote: Thu Jan 05, 2023 3:59 pm Any update from Sony to fix dolby vision issue on the x700/x800?
No, as far as I know. I own both x700 and x800m2
Post by RESET_9999 » Thu Jan 05, 2023 4:40 pm
I doubt this will ever be fixed and the different L1/L2 responses doesnt seem to affect actual content. Also, I don't think it's related to CMV2.9 vs CMV4.0 devices.
Here's my observations so far...
X800m2/x700:
L1 low contrast and L2 offset 0.75 doesnt work
no issue with "multi" pattern
Shield:
color issues (bug still there, checked recently)
issues with "multi" pattern (blue banding and clipping conversion issues)
C2 internal player:
all the L1/L2 metadata works
issues with "multi" pattern ( clipping conversion issues)
Movies with source max_pq 3696 (MDL 4000nits) look a lot darker than the x800/x700/shield: https://www.youtube.com/watch?v=sl_wopsmdmc
C8 internal player:
No issue with "multi" pattern
FireTV cube latest gen and probably firestick max:
issues with "multi" pattern (tracking issue)
overall darker image
Chromecast GTV (cmv2.9 device):
L1 optimal doesnt work
L2 looks quite different in LLDV than in tv-led
the first test showed that it produced a brighter image but I still have more tests to do.
https://slow.pics/c/pEEQBJJD
no issue with "multi" pattern but if you FF/RW, the pattern start flickering.
I know @quietvoid found out that the "multi" pattern "may" have luma issues but I'm not sure about that because I checked the other versions of the pattern and they all behave exactly the same.
So unless Stacey Spears did the same mistake for all the patterns, I believe this is just how the pattern is supposed to work and it truly exposes issues on devices (shield and C2)
They also all show 10 000 nits but it's only because of a couple of pixels in the middle of the frame. The pattern are really 600/1000/4000 or 10 000 nits so I redid all the versions without trim passes and with proper source_max pq and maxcll/fall. You can find them here: https://drive.google.com/drive/u/1/fold ... 52Ja3JEc7c
quietvoid
Post by quietvoid » Thu Jan 05, 2023 5:05 pm
RESET_9999 wrote: Thu Jan 05, 2023 4:40 pmI know @quietvoid found out that the "multi" pattern "may" have luma issues but I'm not sure about that because I checked the other versions of the pattern and they all behave exactly the same.
Someone looked at that pattern recently: https://www.youtube.com/watch?v=JzbXYgZ4vSY
I don't remember the conclusion but maybe there's new relevant info.
Also if it's of any interest, I recently made a L11 whitepoint test: https://mega.nz/file/cUcCxIIQ#rlWlhxVeZ ... CbdsNWhUQY
The image should change whitepoint from warm to cool, if the playback chain supports CM v4.0.
It only works on my FTV stick 4K Max, not the C2 internal player.
Post by RESET_9999 » Thu Jan 05, 2023 5:40 pm
quietvoid wrote: Thu Jan 05, 2023 5:05 pm
thanks , will test
Post by RESET_9999 » Thu Jan 05, 2023 11:36 pm
quietvoid wrote: Thu Jan 05, 2023 5:05 pm Also if it's of any interest, I recently made a L11 whitepoint test: https://mega.nz/file/cUcCxIIQ#rlWlhxVeZ ... CbdsNWhUQY
no effect on the shield and C2. Too bad the firestick doesnt track ST2084 well because it's the only device that does all the metadata correctly.
This pattern is great to expose the shield red push though, clearly visible on the white waves
MP4 versions here: https://drive.google.com/drive/u/1/fold ... fx6vRYDEfs
Edworld
Post by Edworld » Sun Jan 08, 2023 11:05 pm
first time using the script
Downloaded 1.7.0 and started the process to convert my mkv file to something that my Sony 800m2 will play. I selected 4,2 and it's been doing its thing.
Besides not knowing why I selected 2, how long does it take to finish? Movie is 1917 and the process is well over an hour. Windows 10 computer and temp folder is in an external drive
BadSector81
Post by BadSector81 » Mon Jan 09, 2023 10:47 am
EG:
pip install ijson
Hi! All. Installing won't work with Python 3.11.1, try Python 3.10.9. and it will be fine. Using W11.
Post by RESET_9999 » Mon Jan 09, 2023 11:59 pm
I made some new L1 test files. Something is definitely not working on the x800m2/x700, will do a side-by-side comparison video later...
The files have nine L1 metadata changes, it goes from max_pq 100nits to 10 000nits.
P5 version (≈700nits): https://drive.google.com/file/d/1AzIA9e ... share_link
P8 version (≈3600nits): https://drive.google.com/file/d/1yY33Df ... share_link
** you may have to remux them to TS or MKV
Trees
Post by Trees » Tue Jan 10, 2023 3:23 pm
Hi guys. Does anyone know if it's possible to add 2160p WEB-DL HDR10 and DV to a 2160p SDR remux? Unfortunately, the UHD is SDR whereas the WEB-DL is available in HDR10 and DV.
