Can't Install on Debian 11
Faber
Post by Faber »
I'm trying to install MakeMKV 1.14.7 on Debian 11 (AKA Bullseye), but there's a dependency problem. Debian 11 uses QT version 5, but it doesn't have the libqt5-dev package. I'd rather not have to remove QT version 5 and install version 4 from the Debian 10 repository. What can I do to get MakeMKV installed? Is there a different dependency I can use?
Re: Can't Install on Debian 11
The main question is, why doesn't the repository have the dev package for qt5, if it is using it?
Faber
Post by Faber »
Woodstock wrote: Wed Jan 22, 2020 2:42 pm The main question is, why doesn't the repository have the dev package for qt5, if it is using it?
Yeah, I've been wondering about that. The strangest thing about it is that the Unstable and Experimental repositories don't even have it.
blackrook
Post by blackrook »
Faber wrote: Wed Jan 22, 2020 1:58 am I'm trying to install MakeMKV 1.14.7 on Debian 11 (AKA Bullseye), but there's a dependency problem. Debian 11 uses QT version 5, but it doesn't have the libqt5-dev package. I'd rather not have to remove QT version 5 and install version 4 from the Debian 10 repository. What can I do to get MakeMKV installed? Is there a different dependency I can use?
Yeah, I saw that too. It seems like the only solution would be to install it as a flatpack or a snap. As of 1-2-2023, libqt-5 is not in any of the Debian repos.
mathias
Post by mathias »
(Please don't revive dead threads....)
It's 100% possible to install/run makemkv on bullseye -- it's what I've been doing the last year and a half. If you really want to build it yourself (and not take advantage of the pre-built packages), qt5 development packages are available: https://tracker.debian.org/pkg/qtbase-opensource-src.
Badlou101
Post by Badlou101 »
blackrook wrote: Mon Jan 02, 2023 9:43 pm
Both Flatpaks and Snaps are generally more secure than a deb install anyways.
Faber
Post by Faber »
Badlou101 wrote: Thu Jan 05, 2023 2:41 am
I'm not really a big fan of Flatpaks because they don't really integrate with the rest of the system very well.
