Help flashing correct FW for encrypted WH16NS40 1.05 Drive
joeys522
#1 Post by joeys522 » Thu Jan 05, 2023 12:09 am
Just got an WH16NS40 drive made in July of 2022 with encrypted firmware 1.05. What I'm confused about is what encrypted FW do I use to flash it? I have an idea what FW, but just want to make sure I'm doing it right so I don't brick the drive. I saw in the flashing guide that the newer encrypted fw cant be flashed easily which is why I'm a little confused.
"The newer OEM firmwares cannot be flashed easily due to the additional downgrade checks implemented by the drive/firmware manufacturer. If your drive has one of these firmwares, and there is no MK version of the same firmware/drive model or higher number, you will have to sidegrade to Asus 3.10MK (for compatible ASUS 5.25 drives ONLY) or (LG WH16NS60 1.02MK for compatible LG 5.25) or (BU40N 1.03MK LG Slim drives ONLY) respectively. (Note: MK firmware is available for firmware versions mentioned above.) Keeping the flashing of firmware in these scenarios within their respective family of drives/firmware (e.g ASUS firmware for ASUS drives and LG firmware for LG drives) at this stage of flashing. Then afterwards if that initial flash is successful you can move to different firmware respectively if you would like a different and compatible firmware version for the drive in question."
Re: Help flashing correct FW for encrypted WH16NS40 1.05 Drive
#2 Post by Billycar11 » Thu Jan 05, 2023 1:50 am
Follow linked guide for fw recommendation
But yeah WH16NS60 1.02 is the one to flash
joeys522
#3 Post by joeys522 » Thu Jan 05, 2023 1:54 am
Is it the LG WH16NS60 1.02MK or without the MK? "The all you need firmware pack" doesn't include the MK fw.
#4 Post by Billycar11 » Thu Jan 05, 2023 2:37 am
just renamed it for easier use its all mk or de
originally there was no gui people used to have to type it when i made it so shortened it
joeys522
#5 Post by joeys522 » Thu Jan 05, 2023 2:43 am
It worked. Thank you so much for the help. Much appreciated!
joeys522
#6 Post by joeys522 » Thu Jan 05, 2023 4:32 am
I'm getting different errors in the log...
A lot of these..
Title #00018.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
and a lot of these..
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '104994816'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '104994816'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '105129984'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '105129984'
I tried a different disk and it seemed to work fine without errors.. So these errors must be because of the disk itself.
#7 Post by Billycar11 » Thu Jan 05, 2023 1:52 pm
A lot of these..
yeah read errors are not caused by firmware that are either the disc or the drive
joeys522
#8 Post by joeys522 » Thu Jan 05, 2023 3:40 pm
A lot of these..
All errors went away when I unchecked all of the other bonus features on the disk and only had just the movie selected. The disk that gave me trouble went perfect after that. Tried 3 others same way and went just as smooth no errors. Thank you so much for the help!
