Can't Install on Debian 11
Faber
Post by Faber » Wed Jan 22, 2020 1:58 am
I'm trying to install MakeMKV 1.14.7 on Debian 11 (AKA Bullseye), but there's a dependency problem. Debian 11 uses QT version 5, but it doesn't have the libqt5-dev package. I'd rather not have to remove QT version 5 and install version 4 from the Debian 10 repository. What can I do to get MakeMKV installed? Is there a different dependency I can use?
Re: Can't Install on Debian 11
Post by Woodstock » Wed Jan 22, 2020 2:42 pm
The main question is, why doesn't the repository have the dev package for qt5, if it is using it?
Faber
Post by Faber » Wed Jan 22, 2020 7:37 pm
Yeah, I've been wondering about that. The strangest thing about it is that the Unstable and Experimental repositories don't even have it.
blackrook
Post by blackrook » Mon Jan 02, 2023 9:43 pm
Yeah, I saw that too. It seems like the only solution would be to install it as a flatpack or a snap. As of 1-2-2023, libqt-5 is not in any of the Debian repos.
mathias
Post by mathias » Wed Jan 04, 2023 10:51 pm
(Please don't revive dead threads....)
It's 100% possible to install/run makemkv on bullseye -- it's what I've been doing the last year and a half. If you really want to build it yourself (and not take advantage of the pre-built packages), qt5 development packages are available: https://tracker.debian.org/pkg/qtbase-opensource-src.
Badlou101
Post by Badlou101 » Thu Jan 05, 2023 2:41 am
Both Flatpaks and Snaps are generally more secure than a deb install anyways.
Faber
Post by Faber » Mon Feb 13, 2023 6:24 pm
I'm not really a big fan of Flatpaks because they don't really integrate with the rest of the system very well.
