Titles assumed fake on NCIS Hawaii Season 1 DVD
betanonuser
Post by betanonuser »
Hey all, I'm getting this commentary when I'm trying to back up my NCIS Hawaii Season 1 DVD... any advice?
MakeMKV v1.17.2 darwin(arm64-release) started
Optical drive "BD-ROM HL-DT-ST DVDRW GS23N SB08 KZZA4UJ4149d" opened in OS access mode.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'BD-ROM HL-DT-ST DVDRW GS23N SB08 KZZA4UJ4149' at offset '0'
Cells 1-1 were removed from title start
Title #4 declared length is 0:41:29 while its real length is 0:00:00 - assuming fake title
Title #5 declared length is 0:41:05 while its real length is 0:00:00 - assuming fake title
Title #6 declared length is 0:41:03 while its real length is 0:00:00 - assuming fake title
Title #7 declared length is 0:41:33 while its real length is 0:00:00 - assuming fake title
Title #16 in broken titleset was skipped
Title #17 in broken titleset was skipped
Title #18 in broken titleset was skipped
Title #19 in broken titleset was skipped
Title #20 in broken titleset was skipped
Title #21 in broken titleset was skipped
Re: Titles assumed fake on NCIS Hawaii Season 1 DVD
The unrecovered read errors are a bad sign. Have you tried gently cleaning the disc?
betanonuser
Yes but they’re brand new discs.
Ezatoka
Post by Ezatoka »
Maybe another DVD opening mode can help: viewtopic.php?f=7&t=28541
"Brand new" means nothing as far as clean disks. Packaging of disks can cause contamination that makes disk hard to read without cleaning.
If I get a title that's freshly-distributed, it's less likely to need cleaning. If it's been around for several months, then I keep the cleaning stuff handy.
betanonuser
Woodstock wrote: Wed Jan 04, 2023 7:20 pm "Brand new" means nothing as far as clean disks. Packaging of disks can cause contamination that makes disk hard to read without cleaning.
Thanks for the advice, I’m new to backing my stuff up, only been doing it for the past few weeks
