Titles assumed fake on NCIS Hawaii Season 1 DVD
betanonuser
Post by betanonuser »
Hey all, I'm getting this commentary when I'm trying to back up my NCIS Hawaii Season 1 DVD... any advice?
MakeMKV v1.17.2 darwin(arm64-release) started
Optical drive "BD-ROM HL-DT-ST DVDRW GS23N SB08 KZZA4UJ4149d" opened in OS access mode.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'BD-ROM HL-DT-ST DVDRW GS23N SB08 KZZA4UJ4149' at offset '0'
Cells 1-1 were removed from title start
Title #4 declared length is 0:41:29 while its real length is 0:00:00 - assuming fake title
Title #5 declared length is 0:41:05 while its real length is 0:00:00 - assuming fake title
Title #6 declared length is 0:41:03 while its real length is 0:00:00 - assuming fake title
Title #7 declared length is 0:41:33 while its real length is 0:00:00 - assuming fake title
Title #16 in broken titleset was skipped
Title #17 in broken titleset was skipped
Title #18 in broken titleset was skipped
Title #19 in broken titleset was skipped
Title #20 in broken titleset was skipped
Title #21 in broken titleset was skipped
Re: Titles assumed fake on NCIS Hawaii Season 1 DVD
The unrecovered read errors are a bad sign. Have you tried gently cleaning the disc?
betanonuser
Yes but they’re brand new discs.
Ezatoka
Post by Ezatoka »
Maybe another DVD opening mode can help: viewtopic.php?f=7&t=28541
"Brand new" means nothing as far as clean disks. Packaging of disks can cause contamination that makes disk hard to read without cleaning.
If I get a title that's freshly-distributed, it's less likely to need cleaning. If it's been around for several months, then I keep the cleaning stuff handy.
betanonuser
Woodstock wrote:
Wed Jan 04, 2023 7:20 pm
Thanks for the advice, I’m new to backing my stuff up, only been doing it for the past few weeks
