nekno
Post by nekno »
Has anyone run into issues with the Sony X700 or X800M2 where 4K files that aren't exactly 2160p resolution get down-res'ed to 1080p? Any fix for this with DAR/SAR headers?
I have a file that's 3840x2080 instead of 2160 and the X800M2 is playing it back with DV but outputting 1080p.
realbabilu
Post by realbabilu »
staknhalo wrote:
Sun Oct 30, 2022 10:27 pm
https://mega.nz/file/VSYQHLaT#KrMwvoO4 ... ej9gTN2P7o
DV test files
edit: Apple devices will need to remux files first in mp4box
Best for apple device since iphone4 is Subler. It has mp4 compatibility with dolby vision / atmos although i dont tested it now since departure to android.
ArArdin
Post by ArArdin »
nekno wrote:
Fri Dec 30, 2022 7:37 am
Pitty your player doesn't just pad with black bars. Or even perform a minor stretch. Sony players have always had a reputation showing unforbidding behaviour towards non-compliant media. They clearly haven't changed. Without recoding, I very much doubt if a fix is possible for your video.
Where I assume it needs to be muxed in (m2)ts. Mkv does offer some tinkerings on container level, however there are very few players that honour certain headers.
lolipeid47
Post by lolipeid47 »
Hey guys, :D hope ur day is fine :oops:
anyone knows how RESET_1999 do to get number of dynamic frames inside a movie (rpu.json) ?
like he does here
=> https://docs.google.com/spreadsheets/d/ ... edit#gid=0
=> Bad.Times.El.Royale.2018 iTunes Shots static DV: only 9 shots for the whole movie.
https://justpaste.it/47641
what's the commandline to use on my RPU.json to get the exact number of dynamic shots like he does ? :mrgreen:
lolipeid47 wrote:
Tue Jan 03, 2023 1:27 pm
dovi_tool.exe info -s rpu.bin
or
2-2 in my script (in my signature)...
strange, my x800m2/x700 doesnt downscale to 1080p with cropped 4k videos but it makes the letterbox grey and it's unwatchable.
lolipeid47
thank you man :P ;) :3
lolipeid47
thank you but I want also to print the dynamic shots in a json file ? any idea man ;-)
i want it just like you like this https://justpaste.it/47641 but havent found my way yet
ragico
Post by ragico »
Welcome back RESET_9999
jlpsvk
Post by jlpsvk »
anybody can help with python for dovi_scripts???? i'm stucked on "models" module... can't install because of "references" module not found... and can't install that... pymodels again stuck at "props.references"
jlpsvk wrote:
Tue Jan 03, 2023 8:53 pm
I'm guessing you're trying to plot DV (6-2-3) ?
1-Uninstall any python version you have and reboot.
2- get and install python: https://www.python.org/
3- Open a CLI windows and type 1 by 1 all the required modules:
EG:
pip install ijson
lolipeid47 wrote:
Tue Jan 03, 2023 6:31 pm
2-4 in the script or see: viewtopic.php?p=123221#p123221
ragico wrote:
Tue Jan 03, 2023 7:45 pm
:D
jlpsvk
Post by jlpsvk »
RESET_9999 wrote:
Tue Jan 03, 2023 10:25 pm
EG:
pip install ijson
yes... 6-2-3
tried that... no luck... :-/ models keeps asking for missing "base", then "props"... both installed ok, but "references" are a showstopper
lolipeid47
ty RESET_1999
your answers helped me tremendously, I'm now fully operationnal 8) :mrgreen:
jayper
Post by jayper »
Thrilled to have you back!
ArArdin
Post by ArArdin »
Good to see you back, RESET_9999 :)
deadchip12
Post by deadchip12 »
Any update from Sony to fix dolby vision issue on the x700/x800?
