explorerof314
Post by explorerof314 » Mon Dec 26, 2022 1:47 am
Hi, I'm total n00b here..., I'm reading this forum for last few days, and still unsure if it is safe to flash my drive and what FW should I flash it to. What confuses me is the message:
Does it not suggest that the drive will support LibreDrive blob on unmodified firmware?
Also my firmware version looks strange - it is A102, e.g. I can barely find any info about this drive. This drive is internal laptop drive from Dell.
My drive information:
Product: BD-RE BU40N
Revision: A102
Serial number:
Firmware date: 2119-05-03 17:43
Bus encryption flags: 1F
Highest AACS version: 61
Is it safe to flash and what should I flash it to?
When I tried my first UHD disc today, I've got:
Saved AACS dump file as C:\Users\proko/.MakeMKV/MKB20_v61_Game_Of_Thrones_Season_1_Disc_1_EE7D.tgz
Any help would be greatly appreciated.
Post by Billycar11 » Mon Dec 26, 2022 3:59 am
Revision: A102
Serial number:
Yes it's safe to flash follow BU40N steps and it will work or email me for an auto flash kit
explorerof314
Post by explorerof314 » Mon Dec 26, 2022 4:17 pm
Thank you for your answer.
Is my understanding correct that I should go with:
The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
or should I go with MK firmware like \mk-firmware-pack-20200720\MK\HL-DT-ST\BU40N-N-Main\HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin ?
My further concern is that I tried to use "Read firmware" option from SDFtool and it produced tar file of 72kb with few tiny files inside. I assume this is not what I can use to re-flash original firmware, if things goes wrong? Further is there any option to backup existing firmware, "just in case" (or in case someone here would be interested with A102 which seems not-typical BR drive)?
Interestingly according to SDFtool my drive firmware is "not encrypted". Does it change anything? I haven't put any BD into this till yesterday as my significant other got UHD disc set and trying to view this on TV ;), hence my interest in MakeMKV software, which BTW is awesome initiative.
explorerof314
Post by explorerof314 » Tue Dec 27, 2022 4:27 pm
... or email me for an auto flash kit
I cannot recommend highly enough the help, I've received from Billycar11.
His help / knowledge & custom flash script is worth every penny.
My drive is now "fixed" and I'm fully enjoying MakeMKS software.
JacobV
Post by JacobV » Tue Dec 27, 2022 8:44 pm
Looking at the Mac/Linux Command instructions
I understand everything except step 4, "copy sdf.bin and the firmware file extracted from theall you need firmware pack into /tmp folder"
Where is /tmp folder and how would I do this? The commands are included for the other steps but not sure I'm fully comprehending how to do this
Post by dcoke22 » Thu Dec 29, 2022 8:49 pm
On Mac, Linux, or other Unix based computers, the path separator is '/'. When a / is the first character of a given path, that means start at the root of the filesystem. So, where is /tmp? It is literally at /tmp; a folder called 'tmp' at the root of the filesystem.
However, in the context of the steps to flash a drive on a Mac or Linux machine, '/tmp' just means in a temporary folder somewhere. It doesn't really matter where, just so long as you know where. Then, in step 7, instead of /tmp/sdf.bin, it would be wherever you unzipped it all to.
For example, if you're on a Mac, and you created a folder on your desktop called 'makemkvstuff' and you download sdf.bin into that folder, then the path would be something like:
/Users/<your user name>/Desktop/makemkvstuff/sdf.bin
One of the handy things a Mac can do is if you find a file in Finder and you'd like the full path of it in Terminal, drag the file from finder into Terminal, and the full path of that file will show up on the Terminal command line.
https://support.apple.com/guide/termina ... rml106/mac
fganter
Post by fganter » Sat Dec 31, 2022 5:26 pm
Sorry if I did not catch this in this massively long thread...
Is there a list of drives prioritized by reliability - i.e. ability to consistently read UHD discs?
I just started using a BP60NB10. I'm about 9 discs in and 2 (22%) have had read problems, even after cleaning the disc.
Is there any drive that is considered better than the BP60NB10? While I would prefer an external drive, as my next PC case will likely not have a drive bay, if there is an internal drive that is considered loads better than the BP60NB10, I would certainly consider it.
Thanks for your help.
Post by d00zah » Sat Dec 31, 2022 5:40 pm
1st post. While pricier, Pioneer drives are raved about for reliability. Followed by the less expensive LG BU40N. See Recommended UHD Drives to get: section.
A benefit of splurging for a Pioneer is there is no need to perform a FW flash (other than, maybe, a Pioneer-supplied update, IIRC).
Post by Billycar11 » Sat Dec 31, 2022 5:45 pm
The bp60 is a good drive pretty much a bu40n but with the sata board removed.
Did you flash the drive?
fganter
Post by fganter » Sat Dec 31, 2022 8:20 pm
Good to know. Sounds like I got a winner, then.
Yes. I would not have been able to rip 7 of 9 if I didn't, correct? (I'm not being snarky. I'm legitimately asking.)
Post by Billycar11 » Sat Dec 31, 2022 8:41 pm
Some people don't differentiate between bluray and UHD bluray seen it many times they say they rip 4k and they are ripping DVDs sometimes lol. But if all the discs were UHD then yeah you flashed it right.
Badlou101
Post by Badlou101 » Mon Jan 02, 2023 7:20 pm
I just recently got a LG WH14NS40 and was trying to flash in on Arch Linux (kernel 6.1.1). I followed the instructions and then came across this:
 [REDACTED@archdesktop ~]$ sudo makemkvcon f -d /dev/sr0 -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Drive "/dev/sr0" not found
any ideas?
Oberon
Post by Oberon » Fri Jan 06, 2023 12:27 am
Thedeanorama wrote:
Thu Sep 29, 2022 11:06 pm
I'm pulling out what's left of my hair.
I have an LG WP50NB40 NB52 that I'm spinning my tires on. I'm using the SDFtool Flasher v1.3.4 to flash the drive. I've tried flashing HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin from the "All that you need firmware pack" to get to stage one of these steps (mainly because I ran into a roadblock sourcing "BP50NB40-NB50-1.03MK") :
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty
The only reason I figure I'm failing is that no matter what I do, and how many times I'm "successful" per SDFtool, BP60NB10 1.00_HBD never takes hold (see link below). For the life of me don't know where I'm going wrong. I'm not new to flashing devices but this is completely evading me.
https://photos.app.goo.gl/tbZiPzKSvKpxTErXA
I'm having the exact same issue with my NB52 using the same procedure. Cannot get it to BP60NB10.
Post by MartyMcNuts » Fri Jan 06, 2023 2:01 am
There is no need for the HBD firmware anymore. To flash the WP50NB40/BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to either WP50NB40 (NB50) 1.03-MK or BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the WP50NB40 (NB50) 1.03-MK or BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select either the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box. Whichever one you want to use.
4. Click START
The process takes about 30-40 seconds to complete.
fosaq
Post by fosaq » Sat Jan 07, 2023 1:11 pm
I found a USB enclosure (purchased with a BU40N) that work with 9.5 mm ultra slim drives and support flashing, especially interesting for people in europe because I was unable to get one in the list.
DeLOCK 42603
https://www.delock.com/produkt/42603/merkmale.html
There are other variants, i.e. with USB-C connector instead of USB-A or that support other drive sizes (12.7 mm). They will probably also work.
