Linux native flashing
kahomono
Re: Linux native flashing
Post by kahomono »
Thanks, Mike!
spl147
Post by spl147 »
i cannot get this to work!
~ # /opt/makemkv/bin/makemkvcon f -d /dev/sr0 -f /config/data/sdf_00000070.bin flash -i /
config/data/WH16NS60-1.02.bin
Unknown command
Command produced error code 0x8fffffff
Big-rome
Post by Big-rome »
I got this to work on my synology nas running makemkv in a docker container.
Big-rome
Post by Big-rome »
flashing instructions on a synology nas with docker
sudo docker exec -ti CONTAINERNAME sh
wget http://www.makemkv.com/svq/sdf.bin
chmod +x sdf.bin
wget https://www.makemkv.com/download/mk-firmware-pack-20200720.zip
unzip -q mk-firmware-pack-20200720.zip
cd /opt/makemkv/bin
./sdftool --list
./sdftool --sdf-file=/tmp/sdf.bin -d /dev/sg* rawflash -i /tmp/mk-firmware-pack-20200720/MK/bla/bla/bla.bin
pr0999
Post by pr0999 »
HereInPlainSight wrote: Wed Apr 01, 2020 11:19 pm
OS device name: /dev/sr0
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BC-12B1ST
Revision: 1.01
Serial number: <removed>
Firmware date:
Bus encryption flags: 12
But, when I try to do anything of interest with the sdftool, I'm not sure if it has anything to do with the firmware date being missing, but I keep hitting a wall, which seems best surmised with:
$ ./sdftool.sh -d /dev/sr0 help
No drive tool logic found in SDF.bin
Internal error 0x8d000000
and:
$ ./sdftool.sh -d /dev/sr0 --info
SDF.bin version: 0x006D
Drive Tool SDF not present
Drive Specific SDF not present
Identification SDF present
Of the two missing -- am I supposed to do anything specific to get / provide them? It looks like my drive is supported, just not on this specific firmware, which is... obviously exactly what I'm trying to fix (though I'm not entirely certain if I'm supposed to update to the latest for my system and then downgrade to the BW-16D1HT 3.02 firmware, that seems like what's being recommended but I'm a bit too new to understand the exact benefits, people just keep saying it can be done).
Any guidance on what I'm missing to be able to at least update my firmware would be great.
Did you ever solve this? I also have a 12B1ST at 1.01 and am trying to update it to a libredrive compatible fw, and running into the exact same problem. The devilsclaw flasher from OP also doesn't seem to work...
pr0999 wrote: Sun Aug 30, 2020 9:28 pm
dont mess with an asus on 1.01 your asking for trouble only do this if they have 3.xx not worth it for the other drives
hatch
Post by hatch »
I have an ASUS BW-16D1HT made in March 2020 and I'm having a problem: BD discs do not work after the flashing. CD and DVD discs work. I only tried one BD disc, and it worked before flashing, though it took a while. When inserting the disc, after a while of making "horrible" noises (as described in the Sleep bug), MakeMKV reports "No disc inserted".
I followed these steps:
- Downloaded https://www.makemkv.com/sdf.bin, copied it to /root/.MakeMKV/
- Downloaded https://www.makemkv.com/download/mk-fir ... 200720.zip
- Downloaded and installed makemkv-oss-1.15.3.tar.gz and makemkv-bin-1.15.4.tar.gz (I used a custom installation directory and LD_LIBRARY_PATH to point to the right libmakemkv, if that matters)
- sdftool --info output:
$ sdftool -d /dev/sr0 --info
SDF.bin version: 0x007D
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8109:Possible (with patched firmware)
8001:Drive platform
:MT1959
8010:Harware support
8100:Yes
8011:Firmware support
8101:No
8002:Firmware type
8108:Original (patched version available)
8003:Firmware version
:3.10
8005:DVD all regions
8006:BD raw data read
8007:BD raw metadata read
8009:Unrestricted read speed
[Drive Specific SDF] Embedded Status Message:
8096:LibreDrive mode for this drive is only possible with firmware upgrade (id=%1)
:1C602C3A8BBC
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :ASUS    :BW-16D1HT       3.10:W001601:-
- Flashed with:
$ sdftool -d /dev/sr0 -v rawflash -i mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Loaded SDF.bin version 0x7d
Reading input file mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Current Drive ID: ASUS_BW-16D1HT_3.10_211901041014_KLOK3TB0433
yes
 100% Operation finished
Done successfully
Command produced 0 file(s)
Output of --info after flashing was:
8013:Status
8105:Enabled
8001:Drive platform
:MT1959
8002:Firmware type
8107:Patched (microcode access re-enabled)
:3.10
8100:Yes
8100:Yes
8100:Yes
8100:Yes
8099:Using LibreDrive mode (v%1 id=%2)
:06.2
:0FA242DD4D0B
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :ASUS    :BW-16D1HT       3.10:WM01601:-
- I tried and the BDs that worked before, no longer worked. I checked in a player and the discs keep working, so that's not it.
- I realized that the instructions mention that the firmware needs to be updated with the 'enc' option, so I tried flashing again:
sdftool -d /dev/sr0 -v rawflash enc -i mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
yes
Done successfully
But that did not restore access to the BR discs.
Did I brick my unit by forgetting to upload the firmware with the 'enc' option the first time?
Did I miss any steps? Should I downgrade in order to get firmware that fixes the sleep bug? Where I can find information about downgrading? Where can I get the downgraded firmware for this drive? Putting together all the information necessary to reach this point has already been a bit of a hell.
Skalli
Post by Skalli »
I've wanted to watch BluRays on my Linux PC too, but more importantly help my father get it done. So I bought a drive and this thread helped me a lot, since I stumbled across a few problems, but the solutions were missing, so I registered to write down the steps that helped me, so it might help others too.
Some background, I'm on Manjaro, so MakeMKV ist available via the Arch User Repositories (AUR). Easy to install which also gives the sdftool command line tool. No big effort there, luckily.
I got the drive ASUS BW-16D1HT simply because it was the cheapest compatible drive I could find with ~70€ on Amazon as the time of writing.
But here I ran in the first problem as others: When running sdftool -d /dev/sr0 --info it returned
Drive "/dev/sr0" not found
The path to the disc was correct as it showed it had loaded a disk.
The solution for this was, that the drive was working, but the generic SCSI module was not loaded. The command
sudo modprobe sg
fixed that. sdftool now could access the disc (so could MakeMKV).
In order to load that always you can do this:
su root
echo sg > /etc/modules-load.d/sg.conf
exit
Then MakeMKV can open the disc without the need to run the command each time.
SDF.bin version: 0x007E
8013:Status
8001:Drive platform
:MT1959
8100:Yes
8101:No
8002:Firmware type
:3.10
:1C602C3A8BBC
8013:Status
8001:Drive platform
:MT1959
The only thing missing was now the right firmware.
I used these.
Then figuring out the correct command took a bit as I also got the classic
Unknown command
error messages.
Long story short, after reading this thread it worked for me. So I got it to work with this command:
sdftool -d /dev/sr0 -v rawflash -i ~/Downloads/firmware/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Of course that only works for the ASUS BW-16D1HT. For other drives you need to choose the correct firmware.
After these steps, playback with VLC worked, and backing up with MakeMKV runs fine too.
I hope this helps, in the end it was pretty straight forward, just took a time to gather all the information and filter out what's not applicable.
blazini36
Post by blazini36 »
I'm also a die hard Linux guy so I always like to stumble across threads like this so I had to join. I didn't actually realize BluRays were such an issue on PCs and to be honest I probably played 2 BluRays 10 years ago. I picked up an external drive (Pioneer BDR-XS07S) because I found out that an old anime I'm fond of was released on BluRay and I couldn't find it anywhere else. Tried to play it on my new drive and realized.........blurays are fun lol
I wasn't able to read it with makemkv at first but Skalli's post about loading the module did it. So now I have a disk transcoding. Looks like there is no Libredrive firmware for it yet but I'll be sending the firmware to support so hopefully someone will come up with something.
AndrewR
Post by AndrewR »
I have
# /usr/bin/sdftool -d /dev/sr0 --info
SDF.bin version: 0x0096
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :ASUS    :BW-16D1HT       3.11:W000600:-
# /usr/bin/sdftool --l
Found 1 drives(s)
00: dev_21:1, /dev/sr0, /dev/sr0
  ASUS_BW-16D1HT_3.11_212012011759_KL4LC9F5139
Unfortunately attempt at making full firmware dump meet with:
# /usr/bin/sdftool -d /dev/sr0 dump full
Error: full dump is disabled in this firmware version
DEBUG: Code 4279205893 at viMquYt1v=$Gzk%Z~&aQ#/W!W1[^Pbye:29395034
Command produced error code 0xff0f8005
MakeMKV 1.17.2 is compiled/installed for 32-bit userspace
Partial dump is possible but I guess it will not give me something to flash back if something goes wrong?
You need to flash your drive to MK firmware using -enc since your firmware is encrypted. Use search or start with the tutorial.
viewtopic.php?f=16&t=19634
AndrewR
Post by AndrewR »
so there is currently no way to backup *original* (from my own drive) firmware? I think I'll wait for some time and try pre-installed firmware first ( right now I am more interested in burning, not in UHD ripping. while idea of (partially) open firmware looks attractive ..as long as one can reflash some known-stable variant ...)
Post by d00zah »
AndrewR wrote: Sun Jan 01, 2023 5:04 am so there is currently no way to backup *original* (from my own drive) firmware? I think I'll wait for some time and try pre-installed firmware first ( right now I am more interested in burning, not in UHD ripping. while idea of (partially) open firmware looks attractive ..as long as one can reflash some known-stable variant ...)
Only 1 version back...
https://dlcdnets.asus.com/pub/ASUS/ODD/ ... 190306.zip
viewtopic.php?t=19065#p72109
viewtopic.php?f=19&t=19116#p72108
Note: Functionally, there is little difference between stock & 'patched' FWs other than some 'single-bit' & decryption tweaks:
- downgrade bit ("DE", downgrade (re)enabled)
- microcode access re-enabled ("MK", by MakeMKV author)
- decrypted
