I enabled debugging in preferences, but I don't see "Debug logging enabled, log will be saved as C:\Users\<username}/MakeMKV_log.txt" or anything like that. Is that feature different now? Where are the debug messages logged?
* View
* Preferences
* General
* Log debug messages
Debug logs?
Re: Debug logs?
Did you restart MakeMKV after turning on debug logging?
I'm running version 1.17.2 and I see this message:
MakeMKV v1.17.2 darwin(arm64-release) started
Debug logging enabled, log will be saved as /Users/<username>/MakeMKV_log.txt-
Dougmeister
Re: Debug logs?
Ok. It must not have saved the option... or I clicked "Expert mode" by mistake. All better now. Thanks!
Re: Debug logs?
Both logging and expert mode are "next restart" functions. They just don't go "live" until you close all copies and restart.
TalkTalk1701
Re: Debug logs?
I was just going to ask the same question and so this thread so thanks for the info
