nekno
#7831 Post by nekno » Fri Dec 30, 2022 7:37 am
Has anyone run into issues with the Sony X700 or X800M2 where 4K files that aren't exactly 2160p resolution get down-res'ed to 1080p? Any fix for this with DAR/SAR headers?
I have a file that's 3840x2080 instead of 2160 and the X800M2 is playing it back with DV but outputting 1080p.
realbabilu
#7832 Post by realbabilu » Fri Dec 30, 2022 3:21 pm
staknhalo wrote:
Sun Oct 30, 2022 10:27 pm
https://mega.nz/file/VSYQHLaT#KrMwvoO4 ... ej9gTN2P7o
DV test files
edit: Apple devices will need to remux files first in mp4box
Best for apple device since iphone4 is Subler. It has mp4 compatibility with dolby vision / atmos although i dont tested it now since departure to android.
ArArdin
#7833 Post by ArArdin » Fri Dec 30, 2022 5:51 pm
Pitty your player doesn't just pad with black bars. Or even perform a minor stretch. Sony players have always had a reputation showing unforbidding behaviour towards non-compliant media. They clearly haven't changed. Without recoding, I very much doubt if a fix is possible for your video.
Where I assume it needs to be muxed in (m2)ts. Mkv does offer some tinkerings on container level, however there are very few players that honour certain headers.
lolipeid47
#7834 Post by lolipeid47 » Tue Jan 03, 2023 1:27 pm
Hey guys, :D hope ur day is fine :oops:
anyone knows how RESET_1999 do to get number of dynamic frames inside a movie (rpu.json) ?
like he does here
=> https://docs.google.com/spreadsheets/d/ ... edit#gid=0
=> Bad.Times.El.Royale.2018 iTunes Shots static DV: only 9 shots for the whole movie.
https://justpaste.it/47641
what's the commandline to use on my RPU.json to get the exact number of dynamic shots like he does ? :mrgreen:
#7835 Post by RESET_9999 » Tue Jan 03, 2023 4:37 pm
dovi_tool.exe info -s rpu.bin
or
2-2 in my script (in my signature)...
strange, my x800m2/x700 doesnt downscale to 1080p with cropped 4k videos but it makes the letterbox grey and it's unwatchable.
lolipeid47
#7836 Post by lolipeid47 » Tue Jan 03, 2023 5:48 pm
thank you man :P ;) :3
lolipeid47
#7837 Post by lolipeid47 » Tue Jan 03, 2023 6:31 pm
thank you but I want also to print the dynamic shots in a json file ? any idea man ;-)
i want it just like you like this https://justpaste.it/47641 but havent found my way yet
ragico
#7838 Post by ragico » Tue Jan 03, 2023 7:45 pm
Welcome back RESET_9999
jlpsvk
#7839 Post by jlpsvk » Tue Jan 03, 2023 8:53 pm
anybody can help with python for dovi_scripts???? i'm stucked on "models" module... can't install because of "references" module not found... and can't install that... pymodels again stuck at "props.references"
#7840 Post by RESET_9999 » Tue Jan 03, 2023 10:25 pm
I'm guessing you're trying to plot DV (6-2-3) ?
1-Uninstall any python version you have and reboot.
2- get and install python: https://www.python.org/
3- Open a CLI windows and type 1 by 1 all the required modules:
EG:
pip install ijson
2-4 in the script or see: viewtopic.php?p=123221#p123221
:D
jlpsvk
#7841 Post by jlpsvk » Tue Jan 03, 2023 11:32 pm
EG:
pip install ijson
yes... 6-2-3
tried that... no luck... :-/ models keeps asking for missing "base", then "props"... both installed ok, but "references" are a showstopper
lolipeid47
#7842 Post by lolipeid47 » Wed Jan 04, 2023 1:41 am
ty RESET_1999
your answers helped me tremendously, I'm now fully operationnal 8) :mrgreen:
jayper
#7843 Post by jayper » Wed Jan 04, 2023 8:39 am
Thrilled to have you back!
ArArdin
#7844 Post by ArArdin » Wed Jan 04, 2023 9:55 am
Good to see you back, RESET_9999 :)
deadchip12
#7845 Post by deadchip12 » Thu Jan 05, 2023 3:59 pm
Any update from Sony to fix dolby vision issue on the x700/x800?
