Has anyone run into issues with the Sony X700 or X800M2 where 4K files that aren't exactly 2160p resolution get down-res'ed to 1080p? Any fix for this with DAR/SAR headers?
I have a file that's 3840x2080 instead of 2160 and the X800M2 is playing it back with DV but outputting 1080p.
Best for apple device since iphone4 is Subler. It has mp4 compatibility with dolby vision / atmos although i dont tested it now since departure to android.staknhalo wrote: ↑Sun Oct 30, 2022 10:27 pmhttps://mega.nz/file/VSYQHLaT#KrMwvoO4 ... ej9gTN2P7o
DV test files
edit: Apple devices will need to remux files first in mp4box
Pitty your player doesn't just pad with black bars. Or even perform a minor stretch. Sony players have always had a reputation showing unforbidding behaviour towards non-compliant media. They clearly haven't changed. Without recoding, I very much doubt if a fix is possible for your video.nekno wrote: ↑Fri Dec 30, 2022 7:37 amHas anyone run into issues with the Sony X700 or X800M2 where 4K files that aren't exactly 2160p resolution get down-res'ed to 1080p? Any fix for this with DAR/SAR headers?
Where I assume it needs to be muxed in (m2)ts. Mkv does offer some tinkerings on container level, however there are very few players that honour certain headers.
Hey guys,
hope ur day is fine
anyone knows how RESET_1999 do to get number of dynamic frames inside a movie (rpu.json) ?
like he does here
=> https://docs.google.com/spreadsheets/d/ ... edit#gid=0
=> Bad.Times.El.Royale.2018 iTunes Shots static DV: only 9 shots for the whole movie.
https://justpaste.it/47641
what's the commandline to use on my RPU.json to get the exact number of dynamic shots like he does ?
like he does here
lolipeid47 wrote: ↑Tue Jan 03, 2023 1:27 pmwhat's the commandline to use on my RPU.json to get the exact number of dynamic shots like he does ?![]()
dovi_tool.exe info -s rpu.bin
2-2 in my script (in my signature)...
strange, my x800m2/x700 doesnt downscale to 1080p with cropped 4k videos but it makes the letterbox grey and it's unwatchable.nekno wrote: ↑Fri Dec 30, 2022 7:37 amHas anyone run into issues with the Sony X700 or X800M2 where 4K files that aren't exactly 2160p resolution get down-res'ed to 1080p? Any fix for this with DAR/SAR headers?
thank you man
:3
thank you but I want also to print the dynamic shots in a json file ? any idea man
i want it just like you like this https://justpaste.it/47641 but havent found my way yet
Welcome back RESET_9999
anybody can help with python for dovi_scripts???? i'm stucked on "models" module... can't install because of "references" module not found... and can't install that... pymodels again stuck at "props.references"
I'm guessing you're trying to plot DV (6-2-3) ?
1-Uninstall any python version you have and reboot.
2- get and install python: https://www.python.org/
3- Open a CLI windows and type 1 by 1 all the required modules:
EG:
pip install ijson
2-4 in the script or see: viewtopic.php?p=123221#p123221lolipeid47 wrote: ↑Tue Jan 03, 2023 6:31 pmthank you but I want also to print the dynamic shots in a json file ? any idea man![]()
yes... 6-2-3RESET_9999 wrote: ↑Tue Jan 03, 2023 10:25 pmI'm guessing you're trying to plot DV (6-2-3) ?
EG:
pip install ijson
tried that... no luck... :-/ models keeps asking for missing "base", then "props"... both installed ok, but "references" are a showstopper
ty RESET_1999
your answers helped me tremendously, I'm now fully operationnal
Thrilled to have you back!
Good to see you back, RESET_9999
Any update from Sony to fix dolby vision issue on the x700/x800?
