Hi all, i have 2 pcs and both have suddenly started with this issue where I can browse to the index.bdmv file, but makemkv does not do anything with it. The files are stored on my hard drive, i don't use an optical drive.
Does anyone have any clues about what go on? Something with windows has changed I suspect for both PCs to be affected like this?
I've allowed the program through the firewall. Debug log shows nothing at all. I've instaled the latest buld and still no joy.
I've scoured the internet but still no joy. Will post a video on youtube of whats happening. I've used makemkv for years with no issues and I'm a paid up owner too.
Steve
HELP - unable to open .bdmv index files
GreenBlood
Re: HELP - unable to open .bdmv index files
When opening a copy of a disk on a hard drive, you need the information MakeMKV generally collects from the Bluray disk, if there is any encryption on it still. You did remove that in the original copy-to-disk that you did, correct? If not, you'll need the decryption file...
Is it just one "disk" that's a problem with both computers, or multiple disks?
GreenBlood
Hi, I’m am using bd25 nzbs with Sabnzbd. The index. bdmv file doesn’t open in Makémkv like it used to for years reliably. This is with multiple index.bdmv files from many different files and on both pcs. It’s odd as the file name does not show in the file dialog box once selected like I believe it used to. Although the file looks completely normal in a normal window explorer dialogue.
GreenBlood
I tried opening the file in notepad and this is the kind of thing shown -
INDX0200 N " >@ @ @ @ @ @
Is typical of the contents of a bdmv file or are mine corrupting?
thanks
thanks
You're opening a binary file in an ASCII program... You are NOT going to be able to read it. So, "Yes" is the best answer we can give you.
None of these files are going to be generally readable by text programs.
