Sonic The Hedgehog 2
mhoare1984
#1 Post by mhoare1984 » Thu Dec 29, 2022 10:24 pm
This UHD fails to open with the following message
MakeMKV v1.17.2 win(x64-release) started
Using LibreDrive mode (v06.3 id=067EFCA8EA7E)
Saved AACS dump file as C:\Users\<username>\.MakeMKV/MKB20_v76_Sonic_The_Hedgehog_2_DC5F.tgz
AACS dump is attached
(206.19 KiB) Downloaded 303 times
Re: Sonic The Hedgehog 2
#2 Post by d00zah » Fri Dec 30, 2022 2:26 am
Per the FAQ (a worthwhile read):
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
mhoare1984
#3 Post by mhoare1984 » Tue Jan 03, 2023 5:43 am
Thanks d00zah. Although the disc surface appeared pristine, it was faulty. I got it swapped and the replacement disc ripped with MakeMKV with no issues.
4K Bluray disc quality seems quite hit and miss with read errors at various points through ripping attempts with MakeMKV and similar programs. I never had one completely fail up front before so this is a first.
