Sonic The Hedgehog 2
mhoare1984
Post by mhoare1984 »
This UHD fails to open with the following message
MakeMKV v1.17.2 win(x64-release) started
Using LibreDrive mode (v06.3 id=067EFCA8EA7E)
Saved AACS dump file as C:\Users\<username>\.MakeMKV/MKB20_v76_Sonic_The_Hedgehog_2_DC5F.tgz
AACS dump is attached
Re: Sonic The Hedgehog 2
Post by d00zah »
mhoare1984 wrote: Thu Dec 29, 2022 10:24 pm This UHD fails to open with the following message
Per the FAQ (a worthwhile read):
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
mhoare1984
Thanks d00zah. Although the disc surface appeared pristine, it was faulty. I got it swapped and the replacement disc ripped with MakeMKV with no issues.
4K Bluray disc quality seems quite hit and miss with read errors at various points through ripping attempts with MakeMKV and similar programs. I never had one completely fail up front before so this is a first.
