The Sting
Re: The Sting
Post by d00zah »
jebbook wrote: Thu Dec 29, 2022 10:11 pm Dec 29, 2022 - I just got The Sting 4k uhd movie and fired up makemkv (I did buy this program) and it can't decrypt the video, make a dump file and failed to open disc. Any suggestions fellas? Replies should be on a basic level - turn on the PC. Plug it in stupid.... I have already sent this movie back to the vendor as unplayable. Yes it does play in a 4k TV player.
Thanks.
Per the FAQ (a worthwhile read):
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
