How do I get this one 4K UHD Drive to read and open 4K Blu-Rays on MakeMKV? It keeps saying that it's failing to open the disc.
https://www.amazon.com/Archgon-Premium- ... B07BC9F98J
Here's what's in the "Info" window:
OS device name: /dev/rdisk5
Product: BD-RE BU40N
Revision: 1.02
Serial number: MOBLC2G4549
Bus encryption flags: 1F
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Thank you!
My Drive Can't Read Discs
Re: My Drive Can't Read Discs
What is the actual error it's giving you?
Your drive needs to be flashed to enable libredrive. Your Archgon can be flashed to BU40N 1.03-MK for use with MakeMKV and AnyDVD only or BU40N 1.00 for use with all ripping software.Hardback247 wrote: ↑Thu Dec 29, 2022 3:21 amHow do I get this one 4K UHD Drive to read and open 4K Blu-Rays on MakeMKV? It keeps saying that it's failing to open the disc.
Revision: 1.02
Thank you!
If you aren't sure about doing it yourself you can get an automated Flasher from me (link in signature) or Billy.
