whatsmyname
Post by whatsmyname »
ArArdin wrote:
Tue Dec 13, 2022 12:28 pm
Disregarding red push, the 2019 Shield TV Pro can process FEL?
It will play it but the enhancement layer will be ignored.
ragico
Post by ragico »
@quietvoid
Please can you post your latest Kodi build Nexus RC1?
Many thanks.
quietvoid
Post by quietvoid »
ragico wrote:
Fri Dec 16, 2022 10:09 pm
@quietvoid
Many thanks.
https://mega.nz/file/tF0AxZTS#xoylPrjah ... 2mqoIw12ME
thetoad
Post by thetoad »
Has the firetv cube gen 3 now surpassed the Shield as the best player for DV MKVs as it now supports bitstreaming? It has better DV support, right? (does it use the EL? or also just the RPUs, but better color accuracy?) It doesn't have gigabit ethernet, but the wifi 6E could conceptually compensate for that. I'm wondering what others think.
ragico
Post by ragico »
quietvoid wrote:
Sat Dec 17, 2022 1:27 am
@quietvoid
Many thanks.
Thank you.
ArArdin
Post by ArArdin »
thetoad wrote:
Sat Dec 17, 2022 10:26 am
If I'm not mistaken the latest Cube does not process FEL. There seem to be some audio problems too. I haven't read the whole thread yet, but at AVSforum issues are mentioned about Dolby MAT not always being output and DTS-HD throughput not working.
https://www.avsforum.com/threads/gen-3- ... e.3255950/
Draco1544
Post by Draco1544 »
Hi ! Is it possible to use the dovi_script tool of @RESET_9999 to create a Dolby vision profile 8 mkv and not a ts file ?
Gatorman
Post by Gatorman »
Draco1544 wrote:
Sun Dec 18, 2022 1:17 am
Certainly, you just need to modify the script by setting the "Choose a muxer" option for tsmuxer.popup to "NO" and mkvtoolnix.popup to "YES". You can set any other ts options to "NO" as well.
More reasons to collect physical media. 2019 Shield TV Pro.
Hoosier205
Post by Hoosier205 »
There is nothing wrong with the Shield. It is still the best option.
Trees
Post by Trees »
I'm trying to hybrid a HDR10 DCP Rip and a DV RPU. Problem is, they're of by a few frames. Is it true I don't need to calculate the frame difference anymore and align the two? That's not quite clear to me.
Edit: The HDR10 DCP Rip is 1 frame behind the DV RPU. Do I need to duplicate or remove 1 frame?
Gatorman
Post by Gatorman »
Trees wrote:
Fri Dec 23, 2022 11:07 am
I don't believe it's automated, someone correct me if I'm wrong.
https://drive.google.com/file/d/1MntCbj ... p=drivesdk
duder
Post by duder »
Guys, how can I mux more than two audio tracks in mp4 file with @RESET_9999 dovi_script tool?
I use 7-1-1 steps. But its limited only to two tracks
powdeau
Post by powdeau »
Hi, does anybody already have the new firmware (03.34.55) for C1 and if so, does it fix the L1 bug on x700?
MastaG
Post by MastaG »
Perhaps somebody knows.
But I've created a few movies with the dovi_scripts.
They are single track dual layer profile 8.
I have muxed them to m2ts for playback on the Shield.
The ones with DTS-MA play properly.
However the ones with Dolby TrueHD seem to only play audio, the picture is frozen.
Any ideas?
ArArdin
Post by ArArdin »
MastaG wrote:
Wed Dec 28, 2022 10:50 pm
I've created a few movies with the dovi_scripts. They are single track dual layer profile 8.
How did you do that? I thought P8 was a single layer format.
Regarding the audio issue, it can be helpful if you post the connection chain. It's a bit of a guess now.
I don't know the Shield. But because DTS-MA does work I'd wonder if the tv is the culprit here. Should your Shield connect to the tv directly, it may be possible the tv is able to handle DTS-MA (probably because of the dts core) but it can't handle a TrueHD stream. Should you have muxed TrueHD with embedded AC3 (as opposed to TrueHD only) possibly audio will work if you'd select that AC3-track for playback on the Shield.
