My Drive Can't Read Discs
Hardback247
Post by Hardback247 »
How do I get this one 4K UHD Drive to read and open 4K Blu-Rays on MakeMKV? It keeps saying that it's failing to open the disc.
https://www.amazon.com/Archgon-Premium- ... B07BC9F98J
Here's what's in the "Info" window:
OS device name: /dev/rdisk5
Product: BD-RE BU40N
Revision: 1.02
Serial number: MOBLC2G4549
Bus encryption flags: 1F
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Thank you!
demon
Re: My Drive Can't Read Discs
Post by demon »
What is the actual error it's giving you?
Hardback247 wrote: Thu Dec 29, 2022 3:21 am How do I get this one 4K UHD Drive to read and open 4K Blu-Rays on MakeMKV? It keeps saying that it's failing to open the disc.
Revision: 1.02
Thank you!
Your drive needs to be flashed to enable libredrive. Your Archgon can be flashed to BU40N 1.03-MK for use with MakeMKV and AnyDVD only or BU40N 1.00 for use with all ripping software.
If you aren't sure about doing it yourself you can get an automated Flasher from me (link in signature) or Billy.
