Has anyone bought the full version?
richa58
I have a dvd of One Piece I want to digitize and when ripping DVD I noticed it stops around the 5 hr mark, the DVD goes for about 8hrs. Will buying it fix my problem? Or does anyone know of another DVD ripper? Thanks in advance.
Re: Has anyone bought the full version?
Buying doesn't change what the program does.
If it is stopping, there should be reasons listed in the output of the program. You ARE logging it all, including the extended debug information, correct?
